Old 06-15-2013, 09:24 PM
tx_jayhawk tx_jayhawk is offline
Default Plane Power Bus Voltage Low
I have an interesting voltage problem I am hoping to get some perspective on. Recently, my main bus voltage is in the 13 volt range, as opposed to the 14 voltage range it previously was operating at. The alternator does appear to be working (turning off the alt field in flight drops the voltage much further and produces a large current drain on the battery), but for whatever reason the bus voltage is low. It's like the internal regulator in the PP is only trying to charge it to a lower voltage. I've had the Odyssey battery tested two separate times and it appears to be good. The bus ranges from 12.8 to 13.2. If the battery were bad, I'm assuming the bus voltage would be lower than the ~13.
I've followed the PP troubleshooting, and all connections appear to be good with proper voltage from the field and B lead.
Any thoughts?
THanks,
Scott
Old 06-15-2013, 11:20 PM
tim2542 tim2542 is offline
Default Diode?
I wonder if you lost a diode, if you loose one or two it will still produce power, but not full capacity. You may still see normal voltage but if you load it it will drop off. Load it down with landing lights, seat heaters or what have you, it should hold pretty steady. If it doesn't have someone test it.
Also you may want to check and tighten the engine grounds.
Tim
Old 06-16-2013, 01:00 PM
N15JB N15JB is offline
Just had this discussion with PP after I had a spun bearing with my PP 60 amp alternator. Start by measuring the voltage at the battery terminals and the engine turning 23-2400 rpm(preferably in flight, using well secured leads from the battery terminals to an accurate voltmeter at your side). You should see 14.3-14.4 volts if the alternator is working properly. If that is what you see, it is not an alternator problem. Start looking for poor connections. poor ground, inaccurate panel voltmeter. If you see 13.x volts, PP can repair and turn around your alternator in a day.
Jim Berry
RV-10
Old 06-16-2013, 01:08 PM
AltonD's Avatar
AltonD AltonD is offline
I had a similar problem. Not that low though. I cleaned all the connections on the shunt, master relay, ANL-60 (fuseable link) battery terminals, engine ground. Better. Now showing 14.1-.3. My thought is that that one drip of oil from the dipstick that occasionally drops when I check the oil was causing the problem. I promise to be more careful.
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
Old 06-16-2013, 03:52 PM
Walt's Avatar
Walt Walt is offline
Good idea to clean all the connections, however oil will not cause or create a bad connection, in fact just the opposite, it helps to prevent corrosion.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
