Go Back   VAF Forums > Model Specific > RV-9/9A
Old 06-15-2013, 07:23 PM
jimevison jimevison is offline
Default Fuel Tank attach bracket.
Dwg 38 section E-E shows the Fuel tank attach bracket supported by F 996C reinf angle and refers to Dwg 23 for the assembly hardware. However I can find no reference on Dwg 23 for specification of the two outer bolts through F-996C. AN3 7A bolts pass through the attach bracket, but what are the bolts above and below?
Old 06-17-2013, 05:35 PM
AF_Alan's Avatar
AF_Alan AF_Alan is offline
Default Look closely
The F-966C has two screws top/bottom attaching it to skin, longeron, and the web. The screws are AN509-10R12 countersunk through the skin.
The specific info you are looking for is in the Isometric view below the F-996A bracket with an arrow pointing at the dotted line which represents the lower F-996C screw.
I recommend writing the specs on Sheet 38...I had to search for it a few times before I finally just wrote it on the other sheet.
Good luck!
Alan
RV-9A N984AW
Old 06-17-2013, 08:54 PM
Default Much appreciated.
Sometimes it takes a second set of eyes!
