Old 06-15-2013, 06:15 AM
DragonflyAero DragonflyAero is offline
Default Dynon Skyview versus Garmin G3X
Soliciting anyone's thoughts on the relative merits and/or disadvantages of Dynon's Skyview system versus the Garmin G3X. I am still quite a way off from needing avionics but have started initial research. I will be starting the wings soon. Will I need to decide on a pitot at this point?
Old 06-15-2013, 06:45 AM
newtech's Avatar
newtech newtech is offline
For a starter do an advanced search on "skyview g3x" and read the 51 returned posts. There has been a lot of good info already written.
______________________
Steve Eberhart, W9JUQ
3EV - Evansville, IN
Where is Steve and the Sky Terrier?
RV-7A Slider, O-360 A1A, Catto 3 blade, 2 screen Garmin G3X Classic, GTN 650, Bionics APRS. FLYING since June 24, 2009
EAA Chapter 21
Old 06-15-2013, 07:03 AM
Jesse's Avatar
Jesse Jesse is offline
I can't speak much for the G3X system, but I have a lot of experience from Dynon. The installation of the Dynon, especially if you couple it with the VP-X, is definitely a DIY system. If you are planning on flying VFR, then your panel can be completely (or almost completely) Dynon, with their COM radio, intercom, transponder, GPS, ADS-B, Engine Monitor, Auto Pilot, etc. The graphics and the functionality of the system is fantastic, although I think this could probably be said of all 4 of the main players (AFS, Dynon, G3X and GRT). Their auto pilot now has advanced features like glideslope coupling, etc, but this can also be said for all of the 4. I think I would recommend getting a flight in a plane with both options and deciding for yourself which you like the best. I personally like the more eye-oriented screen of the dynon, but if you split the screen to PFD and Moving Map, then it ends up much like 2 G3X screens, except with no space between them. I find that when I am coming into the vicinity of the airport, I like to go into full screen PFD, which gives you a full 10" of synthetic vision, which shows the runway, traffic, obstacles, etc. You really need to price out both options with the full panel included, then list the features you prefer from each system, and make your decision based on that.
One thing I will say, is that you can do a fair bit of wiring in your airframe, especially if you go with the VP-X, without deciding on your system. I have heard so many comments from people who decided, bought, and weren't even flying by the time the vendor discontinued their system. I have wired a complete airframe (conduits already installed) in less than a week, including installing the instrument panel, after the plane was painted, so you don't need to make your decision yet. Engine options won't change in the next year or 3, but avionics likely will, so I recommend you make your decision when everything else is done, especially if you are going to build it yourself.
You don't need to decide on a pitot yet, but you do want to install a pitot mount. Unless something has changed recently, most of the major pitot tubes will fit in the same mount/mast. If Dynon is one of your options, then run a 2nd pitot line out for your AOA. The weight is negligible, so it won't hurt to run it.
Many people recommend that you get your autopilot servos ahead of time and install them before you close up your wings. I completely disagree. With your wings on a stand, I can install an auto pilot servo in a finished wing in 15 minutes. That way you are not cornered into a specific system too early in your build. Installing a pitch servo bracket in the tail wouldn't hurt, but in my experience most servos mount the same way. People with experience with the G3 may correct me on this. I know the Dynon and TruTrak, and thus the AFS also, servos fit the same mounting plate.
I know it's exciting to think about the avionics you will be flying behind, but it's too early for you to make a decision. Find an opportunity to fly behind both, or all 4, for that matter, and let your decision start to develop from there.
Jesse Saint
Old 06-15-2013, 07:10 AM
ColoRv's Avatar
ColoRv ColoRv is offline
I agree, sit down with your favorite beverage and read what's already in here. With that said, remember that this is an Internet forum. You don't know what is motivating the person who wrote what you are reading. Could be an employee of one of them, could be a shill...you just don't know. Put it this way, remember that guy you met at the fuel pump who told you with conviction that anyone flying a left hand pattern is a dangerous jerk even though you know the AFD shows a left hand pattern for that airport? That guy can type....and he has an efis opinion too.
Use the forum to get an overview and to get up to speed on relative performance...then the work starts, do your own research. You wouldn't buy a car based on a strangers opinion...do your own research on this too. It's a big dollar purchase...treat it as such.
Ever since these systems were released, many of the manufacturers use carrots to improve sales. Dangle a carrot (promised new feature) that sounds amazing and promise its release very soon...and people will buy your system. Often though, that feature or even the entire line is never completed as the next big thing gets released....so when it's time to write your check (which you should delay as long as possible), buy the system that fits your mission based on what it can do right that minute. Don't believe the promises for the future. One last thing...check pricing yourself. Don't take the word or inference made in here...check for yourself and make apple to apple comparisons. You may be as shocked as I was to find that what is assured in here with absolute conviction...is very wrong in reality.
As for the wing servos.... I left a wing bottom skin cleco'd in place and proceeded onward. It left my options open...even doing that I still ended up installing servos based on future promised features that were promised for years and then abandoned, which meant I pulled those servos out and switched brands. If I were to do it again, I would leave that skin off until fuselage was complete, engine hung, canopy done and I HAD to choose a panel....then make a decision.
I bought my panel 6 months ago and I'm confident I bought the best available for my mission and far beyond my capabilities (so I can grow into it)....and there is already a next generation out on most of it....oh and the next gen price dropped. :-(
Put it off as long as possible!
RV-8 Flying
1,235th flying RV8
SARL Race#95
SnF Homebuilt Judge
Old 06-15-2013, 08:32 AM
Brantel's Avatar
Brantel Brantel is offline
Sorry, too busy flying to respond now!!!
Best advice already given, research the archives. Tons of info there!
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 06-15-2013, 09:44 AM
ColoRv's Avatar
Post more videos!!
RV-8 Flying
1,235th flying RV8
SARL Race#95
SnF Homebuilt Judge
