06-09-2013, 08:31 AM
Red Cube FF drop outs to zero flow...
My fuel flow indication from a red cube transducer to a Skyview system have just started to intermittently display a zero flow drop out. No fluctuation of the flow is observed, just an apparent complete loss of signal to zero for several minutes then back to normal.
Any similar experience or troubleshooting thoughts?
Stephen
RV7 powered by a lycoming thunderbolt IO-390
turning a whirlwind HRT prop
with more hours flying than building... 2,430 on the hobbs!
ORCA Flight
Race 771
margarita!
06-09-2013, 08:50 AM
Have not seen this on mine..., assuming your engine didn't die when FF went to 0. I guess I would start with the wiring checking for loose ends, bad crimp..etc.
Ryan Allen, CFII
RV7 N612RA, flying since july 2012
E-170/175
RV10 Tail Kit complete, Wings 90%, fuse on order
Acro Sport 2, building
06-09-2013, 08:54 AM
no erratic indication...
Thanks Ryan, no engine fluctuation or erratic indications typical of a connection issue... I suspect that it is a transducer failure within the red cube but will trace the wire and connection side of things.
Stephen
ORCA Flight
Race 771
margarita!
06-09-2013, 09:58 AM
Had a similar failure.
It was the factory crimped connection.
06-09-2013, 10:25 AM
interesting...
Thanks Brantel, do you recall which wire you found the failure on? I replaced all of the factory ends with d-sub pins and wrapped them with heat-shrink...
Electrically, I am seeing no jump or erratic signal... simply a removal of the signal voltage to 0.0 indicated for several minutes then a return to normal function.
You did not see any erratic fluctuation in the signal or flow?
Stephen
ORCA Flight
Race 771
margarita!
06-09-2013, 12:07 PM
Mine was in the signal wire. It was reading all over the place then it just stopped.
The wire was still in the connector but the wire inside the insulation was broken.
06-10-2013, 08:38 AM
Red Cube
I had an issue with random fluctuating fuel flow indication (no change in engine performance). Called EIS and was told to crimp the h*ll out of the conectors. Used long nosed pliers and a lot of force on all three wires. Problem solved - although I still don't know which lead was the culprit.
06-10-2013, 08:46 AM
not a fluctuating reading...
Thanks pvalovich, as it turns out, I am not seeing a fluctuating or erratic reading... it is normal and regular with expected stability and function and without any power change or other flight change of any kind the signal will drop to zero volts and the indicated fuel flow will drop to zero.. a few minutes later normal function returns.
I inspected the connections and crimps and they do not appear to be the source of the observed loss of signal voltage
Stephen
ORCA Flight
Race 771
margarita!
06-10-2013, 03:59 PM
Is your EIS Grand Rapids? If so, it might well be the transducer. I've had to replace one or two fuel pressure and oil pressure transducers in 5 1/2 years. Symptoms sound identical.
David Maib
RV-10 N380DM
New Smyrna Beach, FL
VAF Paid 1/21/2020
"In '69 I was 21, and I called the road my own"
Jackson Browne
06-10-2013, 04:54 PM
Stephen, I'm curious about how you installed it. I don't recall seeing a photo of where/how you mounted it. Is it on the engine, the firewall, or inside the cabin somewhere? I finished mounting mine on the firewall a while back, after much deliberation and research. I'm curious if this may have anything to do with it.
