Old 06-09-2013, 04:57 AM
bobmarkert's Avatar
bobmarkert bobmarkert is offline
Default TruTrak pitch mount problem
Vans redesigned the way the elevator pitch bell crank structure is built in the RV-8. I have the new version. When I tried to install the TruTrak pitch servo bracket, I ran into a problem. Closely examining the picture TruTrak sent, it looks like TruTrak removed some material from the Vans original design and the rear bolt no longer goes through the fuselage structure (not smart enough to add arrow to picture? sigh?). The hole in the bracket are pre-drilled and when I dry-mounted the bracket the rear holes are too close to the edge. Has anyone else run into this and if so, did you remove some metal or did you live with close/non-existing edge clearance? Thanks for all the replies ahead of time!
This first picture is what TruTrk sent as an example. It looks like the first bolt aft of the bell crank does not tie into the aircraft structure, it only has the spacer between the two sided of the bracket
The following are is my install. I realize the bracket is held up by the bulkhead, but in the example sent by TruTrk in the picture above it is the same way.
Bob Markert
Littleton, CO KBJC
Reserve Grand Champion Oshkosh 2016
Renegade Opposing Solo pilot and other Dirty Odd Jobs
http://www.rmrairshows.com/
2019 dues paid
Old 06-09-2013, 09:43 AM
scard's Avatar
scard scard is offline
Yep, you aren't the only one. I talked with Andrew about that a couple of years ago. He was drinking something that must have come out of a fuel pump, so it probably didn't stick long enough for him to get home and do something about it.
I think I just made up some brackets of my own, but I can't really remember.
Scott Card
CMW E-Lift
