06-08-2013, 03:44 PM
For HSI, just run the 2 arinc out wires to both systems, or all 4 for GPS and NAV. For an arinc feed back into the 430w, you have to choose one system, but it is probably not even needed. As long as both systems can use the same ARINC speed, you should be fine. Then you can see the HSI on both systems without a switch.
I assume you're keeping the ADI pilot, so leaving that tied directly to the 430W is best.
The RS232 aviation data output from the 430W will probably end up going to the Dynon, G3X and A/P.
Btw, a little surprised you're not going Skyview, but this way leaves more things unchanged and less, if anything, that you would need to sell. I wonder if the Gremlins in the Dynons and G3X will fight behind the panel. :-)
Jesse Saint
06-08-2013, 04:05 PM
The gremlins in the D120 are influencing me in the direction of the G3X  .
Seriously the AP is one of the deciding factors in EFIS.
I send in my ADI 2 and the pitch servo with a $1,000.00 and they send me the GX pilot with new servo, no rewire required to the servos.
If I go with the Skyview its a complete new AP and wiring.
One of the main reasons for the upgrade is the ability to fly approaches and I have already upgraded the 430 to a WAAS.
Tim Blake
Colleyville, Tx
RV8a Purchased flying (many changes) Sold
RV-10 Purchased flying.. Panel upgrade complete.
G3X/Dynon/TT
All new interior complete.
Flyin like a dream.
06-08-2013, 04:13 PM
Good info Brantel thanks, I am deleting the mechanical CDI sounds like its just not worth the complications it creates, and just to clarify I am going with one EIS my existing D120.
Originally Posted by Brantel
I see you are planning on re-using a large part of your original panel.
I am not 100% sure on how you intend to connect and use certain parts of your plan with just the layout so I will just give some suggestions and things to think about.
One is the mechanical CDI. While it first seems it would be a good idea to have both an EHSI and a mechanical CDI, sometimes this can introduce issues. For instance, which one is gonna set the OBS/Course? There can be an issue where the mechanical OBS/Course never matches that of the EHSI and this can cause confusion. Also the mechanical knob/resolver in the mechanical unit can sometimes fight the EFIS for control causing erratic operation.
Another thing to consider is the switchology of using common sources to feed multiple EFIS systems. The EFIS makers do a pretty good job of making their user interface easy to use when dealing with their own selection of data sources but when you add additional switches in the mix, it can quickly become confusing as to what is driving what and it also introduces another failure point into the mix and significantly increases the wiring complexity.
Not sure if you were planning to use both the D120 EMS and the G3X EIS but this is a major challenge if you were planing to use both. The issue comes in when trying to share sensors. Anything can be done but it can be a major pain and expensive to do this.
Just some stuff to keep in mind.
It takes guts to tear into a good panel and do an upgrade like this!
Tim Blake
Colleyville, Tx
G3X/Dynon/TT
Flyin like a dream.
06-08-2013, 04:17 PM
That is a wise move. The G3X can run with or without the EIS system being used. The new products even allow you to skip the EIS interface altogether if you don't need it.
Never had a single issue with my D120 so it should work well alongside the G3X.
06-08-2013, 04:30 PM
I sent you a PM, Thanks
After further review today, it appears the center brace has been modified, so common sense would lead me to believe I shouldn't cut into the right brace.
So unless the plans say otherwise I will lower the D120.
Originally Posted by flion
If you have the plans, section 41, pages 2 and 3, details what Van's finds acceptable for modification of the structure behind the panel. If you don't have the plans, give me your email address and I'll send you an e-copy of that section.
Tim Blake
Colleyville, Tx
G3X/Dynon/TT
Flyin like a dream.
06-08-2013, 04:36 PM
I think you need ARINC into the 430W for the OBS mode to work correctly. The 430w may ask for the info if there is no arinc line in but that's awkward to use, at best.
06-08-2013, 06:16 PM
The servos would need to be replaced, but not the wiring. The TruTrak harness is easily adapted to the Skyview system, and the Skyview now will couple approaches. Either way, you will have a very nice system.
On the ARINC into the 430, I have never once used the obs function in over 900 hours of flying and a fair bit of that IFR. Conceptually it is nice, but in practice I don't use it. Ymmv
Jesse Saint
06-09-2013, 03:04 PM
The only time I've used the OBS function on the gps is for ad hoc holds. But I wonder if having it hooked up is part of the TSO? I have no idea. Since it's only 2 more wires, why not just do it.
