Old 06-07-2013, 05:04 AM
swisseagle's Avatar
swisseagle swisseagle is offline
Question Torque value on steel fitting, table JA14A?
Hello
I'm installing my brake lines in an RV-7A, I have a different parking brake valve with steel fittings on valve and hose.
I found many information about aluminum fittings but no torque values for steel fittings. There is ofthen a hint to look in a table named JA14A for the correct values.
I was not able to find this table JA14A!
Does anyone has information about the torque for steel fitting, size 03?
Thanks alot,
Dominik
Dominik
RV-7A, TMX-IO-320, FM-150, Sensenich FP
Flying since 28. April 2016
