Old 06-06-2013, 04:42 AM
RV10inOz's Avatar
RV10inOz RV10inOz is offline
Default ES Airflow fuel pump failures
Has there been many pump failures? At what kind of service life intervals?
We have 800 hours up and had a pump fail. It seemed to be something mechanical internally, not just a jammed lump of debris.
Any history?
______________________________
David Brown
DYNON Authorised Dealer and Installer
The two best investments you can make, by any financial test, an EMS and APS!
Old 06-06-2013, 11:44 AM
N427EF N427EF is offline
David,
what is an ES Airflow pump?
Ernst Freitag
RV-8 finished (sold)
RV-10 Flyer 600 plus hours
Running on E10 mogas
Old 06-06-2013, 02:12 PM
It is the brand name of the standard electric fuel pump sold by Vans for the -10.
Old 06-07-2013, 12:55 AM
ronoc74 ronoc74 is offline
Apparently the Carter P74015 is a direct replacement for the Airflow pump. I don't remeber who said that, it was years ago. Also I have this in my notes, don't know who wrote it:
The 25 micron ( 0.001") filter element for the Flow Ezy Model 6 ILA
filter (as supplied by AFP and Vans) is part number 8504-05. Price on Flow
Ezy's web site shows a price of $40.20 This is a direct replacement for
the stock 174 micron element. FYI Bendix mandates a filter element of no
more coarse than 74 microns.
The finer filter is supposed to increase pump life iirc.
Conor McCarthy
RV-9A 90990 flying
QLD, Australia
Old 06-07-2013, 10:26 AM
hgerhardt's Avatar
hgerhardt hgerhardt is offline
Originally Posted by ronoc74 View Post
Apparently the Carter P74015 is a direct replacement for the Airflow pump. ....
The Airflow pump is also sold as an Airtex E2315. It's an aftermarket semi-universal replacement pump for EFI vehicles that originally came with an external pump.
The easiest way to remember how to get one on the road is to to ask for a high-pressure pump for a '79 Cadillac Seville (the Seville also had a low-pressure pump in the tank). It's available at Rockauto for $77.89.
Old 06-07-2013, 11:24 PM
RV10inOz's Avatar
Seems the original one was a dud from the start. It was always noisy, growling kind of, and when taxiing after refuelling we always had vapour lock issues. After TOC too. Requiring the pump to be turned on.
We have seen particles in the Andair filter too, that I suspect were the pump.
Now all of a sudden rock steady fuel pressures after a hot start and no need for pump on. Same at TOC.
I think it was an obstructive pump with a problem from day 1.
Anyone know how to disassemble them to see what has gone wrong?
David Brown
