Old 06-05-2013, 01:33 PM
Default Ideas for cheap-n-easy FM antenna
The audio player I am installing in my panel is also a FM receiver (no, not a automotive unit, will save that for another post). I don't have much need for the FM, but if there is a cheap and easy way to add an antenna, I might as well do so.
I was thinking about using some single-conductor shielded wire and the strip back one end to act as the antenna. Maybe run it up the front of the roll-bar support or inbed it in the adhesive for the windshield.
Any other ideas? Anyone know what the correct antenna length is for FM 88-108 MHz? Or maybe this is a waste of time and I should just leave it off...
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
Old 06-05-2013, 01:45 PM
Flying again!'s Avatar
Flying again! Flying again! is offline
Originally Posted by WingsOnWheels View Post
The audio play I am installing in my panel is also an FM receiver (no, not a automotive unit, will save that for another post). I don't have much need for the FM, but if there is a cheap and easy way to add an antenna, I might as well do so.
I was thinking about using some single-conductor shielded wire and the strip back one end to ac as the antenna. Maybe run it up the fron of the roll-bar support or imbed it in the adhesive for the windshield.
The quarter wavelength length is about 2.5 feet.
RV-10 N331JH 3rd owner (First flew in 2005, #15 flying)
Northwest Regional 52F
Old 06-05-2013, 02:06 PM
Does your radio have a coax input, or something else?
Truth is modern radios are very sensitive, almost anything will work!
Old 06-05-2013, 02:11 PM
This player is a super-simple device, right now the only antenna connection is a through-hole solder pad on the circuit board. Sounds like a shielded wire with 2.5' exposed would do the job.
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
Old 06-05-2013, 02:20 PM
RV6_flyer's Avatar
My FM Stereo is connected to my spare Nav antenna.
The FM band is close enough to the aviation VHF band that we use in our aircraft that any Aviation VHF antenna should work. Frequencies are close enough and the FM signal is strong enough that it will work. Actually a two-meter ham antenna would also work. You should not have to buy any of these. There are plans to make them that should work.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 06-05-2013, 06:35 PM
BobRv4 BobRv4 is offline
Default Wire
I had a cheap car type cd/fm radio, for an ant, I just had a piece of wire (no shield) ran it behind the panel worked great, could pick up rock/roll 50+ miles out. No need to go crazy.
Old 06-05-2013, 07:19 PM
Walt's Avatar
Walt Walt is offline
Cheap
My favorite, but it does cost a little more that the first one
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 06-05-2013, 09:46 PM
gasman gasman is offline
My FM radio uses my headset cable for the antenna.
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
Old 06-06-2013, 04:43 AM
Starting to sound like a plain-ol' piece of wire will do the job. I was concerned about picking up RF behind the panel, but it looks like that isn't much of an issue. Thanks for the help.
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
