Old 06-04-2013, 04:56 PM
Tom Martin Tom Martin is offline
Default Tying the Tail Down
One of the problems with a tail wheel is how to tie it down. Usually you wrap the rope around the upright spindle, around the tail fork, or combinations of both.
I couple of years ago I welded a small "loop" on the back of the steering arm and it has proven to be very handy. Wayne Hadath, The Rocket Tail Link steering arm, has improved on my idea and made it a standard on all new steering arms.
As an ADDED bonus, if you are the kind of guy that can build an airplane, you can make a push/pull handle to move your airplane around WITHOUT PUSHING ON THE TAIL!!!
I call it a hockey stick tow bar. Weld or bolt a stub to the bottom. I cut a little notch in the bolt that engages the loop on the steering arm
This thread is sponsored by Rivet the Lab and her friend Buck the stray cat
contact Vince Frazier at Screaming Eagle or Wayne Hadath at Just Plane Parts
I feel obligated to admit that I was given a steering arm for the idea.
Tom Martin RV1 pilot 4.6hours!
CPL & IFR rated
EVO F1 Rocket 1000 hours,
2010 SARL Rocket 100 race, average speed of 238.6 knots/274.6mph
RV4, RV7, RV10, two HRIIs and five F1 Rockets
RV14 Tail dragger
Fairlea Field
St.Thomas, Ontario Canada, CYQS
fairleafield@gmail.com
Old 06-04-2013, 05:15 PM
That looks like a very nice fairing. But I don't quite see how the wheel steers. In the photo, it looks as if the fairing over the strut prevents the wheel fairing from rotating. Can you post another photo showing the wheel at an angle? -- Thanks!
And thanks for mentioning the gift, too.
Dave
Old 06-05-2013, 03:05 AM
Lockard's Avatar
Lockard Lockard is offline
The third photo shows the break between the two. It's the photo that shows the bottom of the hockey stick pull bar in the tie-down loop.
It's the honorable thing to do.
Old 06-05-2013, 05:03 AM
rocketbob's Avatar
Tom one thing I learned from my SNF experience is to never tie the tail down with the anchor point some distance aft of the tailwheel. I tied my RV-6 down that way when the tornado came thru and there was ample evidence that the tail was raised and lowered pretty violently, enough to smash the bottom of the fuselage. If I can help it I now put the tie down below the tailwheel spring and scoot the tail back into position and tie it down such the tail cannot move vertically.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 06-05-2013, 06:15 AM
Low Pass's Avatar
Low Pass Low Pass is offline
Thumbs up
Originally Posted by rocketbob View Post
...If I can help it I now put the tie down below the tailwheel spring and scoot the tail back into position and tie it down such the tail cannot move vertically.
And make sure the rudder is either restrained (better) or the whole rudder-steering assy centered to keep it from flopping around.
Old 06-05-2013, 06:32 AM
Tony Spicer Tony Spicer is offline
Yep, Pooner. Gotta get that tailwheel tied down properly!
Sleepy
Old 06-05-2013, 08:28 AM
rocketbob's Avatar
After the great SNF tornado experience I found that most of the damage to the airplane was from not tying the tailwheel down as well as it ought to be, not from Sleepy's -3. Look at the elevator counterweights, that is from the extreme G forces from the tail weathervaning. I had the stick secured aft with the pilots side seatbelt.
N8155F C150 flying
Old 06-05-2013, 09:44 AM
Bob
Good points about tied down location. Typically I put the tie down as close as I can to the tail wheel. In the past I have done this simply to keep people from tripping over the rope. Now you have given me another reason. Placing the tie-down right beside the "loop" on the back of the new steering arm should give you the best of both worlds. It might even lower the possibility of the tail wheel turning and releasing the rudder, which can quickly destroy the rudder if a significant tail wind catches it.
CPL & IFR rated
RV14 Tail dragger
Fairlea Field
Old 06-05-2013, 12:05 PM
dealfair dealfair is offline
Hmmm, Great info Gents. Thanks! An ounce of prevention....
Deal Fair
RV-4 (N34CB)
George West, TX (8T6)
