  #21
Old 06-07-2013, 06:15 PM
Well, it sounds like progress. I wonder if all the previous attempts have left your plugs coated with oil (was it blue smoke?). I'd pull the plugs and have a look.
Old 06-07-2013, 06:32 PM
airtractor8 airtractor8 is offline
Originally Posted by VETE76 View Post
ok, we installed a slick start system. now we get a lot of puffs of smoke and a few "bangs" but no start. any more suggestions?
ty
fred
Sounds like the timing is out on the mags to me. . Check that your mag to engine timing is correct."bangs" and smoke could be the mag firing the fuel/air charge on the exhaust stroke . Did you check the timing with no1 on the compression stroke? That happened to a guy around here with one of those mags. Turned out to be 180degrees out to the engine.
If its a new engine it could also be that the plugs got covered with preserving oil when you started cranking it and are now all gummed up. That also happened around here on an rv7 with new engine.
Old 06-07-2013, 06:38 PM
SportAvServ SportAvServ is offline
Default Start?
I would think if the engine ran on a test stand and only time and hooking up a ignition switch is the difference, then I would disconnect both "P" leads and crank the engine, you can shut it off with the mixture if it starts. Please make sure you have full travel at both ends of the cables with a little bounce at the end of both the throttle and the mixture. Had a friend with his first start about a year ago and his ignition switch was grounding in the run position but not during start. One thing you need to do is to take the injectors out and just spray carb clean through them, also run your boost pump for a couple of seconds with rags under the ends of the fuel lines while the injectors are out. I have started a couple of new (pre ran) IO 360's and they had little bits of stuff in the injectors and the engine's did not want to run. Good luck, be careful out there.
RT
PS. Does your left mag have a spacer (easy to see, it's about an inch thick) between the engine and the mag?
Old 06-07-2013, 07:29 PM
Walt's Avatar
Walt Walt is offline
ty
fred
Please find someone locally to help you resolve your problems, this is the kind of thing that will get you in big trouble on that first flight if you don't know what you are doing
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 06-07-2013, 08:02 PM
Toobuilder's Avatar
+1 on that!
This is beginning to sound very much a "back to basics" situation....
Is the timing correct?
Are the high tension leads routed properly?
Are the p leads/ignition switch terminals correct?
Are the plugs clean?
Are the fuel lines clear?
Is the fuel fresh?
Are the valves operating?
Etc, etc, etc....
These engines are dirt simple... Any competent A&P should be able to verify all of this and more in a few minutes.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 06-09-2013, 02:26 PM
Jesse's Avatar
Jesse Jesse is offline
I have seen a problem before where the leads in the harness were the wrong lengths, so they were on the wrong plugs. The leads will all have a cylinder number as well as T or B. the engine has cylinder numbers at the base of the cylinders on the case. Make sure you have those right, because that could definitely cause the problem you are seeing. If it was run on a test stand, then it should be something simple. Think through and check everything you loosened/tightened on the engine and check that. The plug wires are almost certainly on that list.
Jesse Saint
Old 06-09-2013, 03:08 PM
az_gila's Avatar
az_gila az_gila is offline
Question
Aren't engines sometimes run on the test stand with "spare" factory mags, and then shipped with the new users mags in a seperate box?
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 06-09-2013, 03:15 PM
Jesse's Avatar
I've never heard of that, but it could be. I'd feel conned by receiving an engine that had been run with other components used than the ones shipped with the engine. If you're going to test run my engine, it is for break in, timing, fuel tuning, etc.
Jesse Saint
Old 06-09-2013, 04:48 PM
Fred,
The engine came direct from Lycoming, it is past due to contact the them..
This engine should start with no issues right now without adding anything to augment the ignition system.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
Old 06-09-2013, 06:30 PM
DanBaier's Avatar
DanBaier DanBaier is offline
Yep - I have a Lyc that I bought years ago and that's exactly what was done. Not only the mags, but the carb too. After they took it off the stand, they crated it up and threw in a box for the carb and the mags. (This was a Lyc overhaul.)
The engine I bought from Mattituck came "as run." I believe I did have to reinstall the carb.
Dan
RV7A (N7101) - Flying 10/2008
CFI- SE/ME/Inst
A&P
KC2ZEL
