Although, possibly coincidental, I seem to notice it most often when boost pump is on
It is very possible that it is simply a little spilling from the vent lines, like many others have noticed on their planes. The fact that you stated it was most often noticed when the boost pump is on, tells me there is a tiny fuel leak somewhere. Inspect thoroughly upstream of the boost pump. It takes very little fuel, even just a little weep that will be noticeable by your sense of smell. In any case, when you inspect the fuel lines with a flashlight and a mirror you'll notice blue stains around fittings, if there is a leak.
I flew my 8 for 450 hours and only noticed a little smell on rare occasions when the tanks were full.
On the other hand, I had a smell of fuel in my 10 when the boost pump was on for landing and found a tiny weeping leak around the nipple on the fuel flow sensor.
It's tight now and there is no more smell whatsoever.
