Configuration
It has been a while, but as I remember, I just did the trip through the Dynon install guide, following the instructions in each section.
As for RV12 specific, I do not remember much. The trim, is covered by Van's, but very poorly. I got most of my guidance on trim from VAF, not from Van's. In the engine area there are pre-set values which flow out of the Rotax 912 engine choice you make early on.
My experience was to do what I could and when something did not work, run it down. Usually I found my problem was with some clear instruction I had skipped in the excitement of seeing it all seem to "come alive".
Others will have better recollections.
Keith Williams
Milan, IL
Built RV6 #756, 1989-99, flew until selling 5/2016.
Built RV12 #533, 5/2011 to 11/2012, flying
