08-13-2006, 01:04 PM
double flush rivets?
For the training project, the rivets along the trailing edge skins, through the trailing edge wedge, are supposed to be AD3-3 rivets. These barely make it through all the material. The instructions say they should be "double flush", which I guess makes sense, because when I back-rivet these short rivets through the trailing edge, the shop head is very small,and basically flush with the skin.
My concern is that I can't imagine there will be much/any strength in these rivets... have I misunderstood something?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
08-13-2006, 01:31 PM
Moderator/Tech Counselor
The length rivet used to double flush should be sufficiently long to fill (or nearly fill) in the dimpled and/or countersunk area. You are, in affect, creating a flush head rivet shop head by slowly working the rivet into shape. It is a slow, deliberate process that may require some practice before you rivet trailing edges with the AEX wedge. Combinations of flush set and backriveting are usually necessary.
Roberta
Below are examples of MFG flush heads (black line) and flush shop heads (red line). Care in shooting these will result in nice, flat, shop heads that will nearly look like MFG flush heads.
Roberta Hegy
Built/Flew an RV-7A
Air Troy Estates, East Troy, WI
Ford Expedition and TRICE "Q"
Built Glen L "ZIP" Classic Outboard Runabout and Super Spartan Hydroplane
Glen L Torpedo
08-13-2006, 01:33 PM
Nope, you haven't.
Instead of a 1 1/2 diameter unbucked protrusion, a rivet destined for double flush is about 1 diameter proud of the shop head surface. If any longer, the shop head won't be contained within the dimple/c'sink.
John Siebold
08-13-2006, 02:17 PM
Thats how they shold look, like it didnt fill the countersink all the way on the shop head side. The tricky thing here is getting them all set without putting a big bow in the trailing edge.
Mike Sumner
Castaic, Ca
08-13-2006, 02:26 PM
The rivets for the trailing edge are AN426AD3-3.5 the 3-3 are for the stiffers
Mike Crowe
McDonough GA
RV8A
08-14-2006, 07:21 AM
the plans for the practice project said to use a flat (mushroom) rivet set. What does "mushroom" refer to here?
Phil
RV9A (SB)
Ottawa, Canada
08-14-2006, 07:47 AM
Mushroom refers to the shape of the rivet set, also called a flat set but if you look from the side it looks like a mushroom. There is a slight parabolic shape to the surface, not quite flat. Just use your normal flush riveting set, you'lll be fine.
Rick Sked
