Old 05-29-2013, 08:27 AM
mbundy mbundy is offline
Default Which baffles for XP-409
Trying to find the best Vans baffle kit as a starting point for the XP-409 going in my Bearhawk. While it won't be a 'perfect fit', it provides a good starting point...So, based on the picture, can someone tell me which baffle kit I should order?
Mike Bundy
Building a Bearhawk
Old 05-29-2013, 08:55 AM
deek deek is offline
Default LSE
Can't help with the baffles but you might consider replacing the LSE Hall Effect Module with either the std or mini direct crank trigger; you already have the correct flywheel/ring gear assy.
deek
'83 LongEZ - N888EZ 3,671 hours
'89 LimoEZ - N26EZ 686 hours (sold)
A couple of Glasairs and a Lancair 320...
Next: a RV14 need something to build
Old 05-29-2013, 09:22 AM
mburch's Avatar
mburch mburch is offline
Looks like a parallel-valve Lycoming with forward induction... the baffle kit for the IO-360-M1B would probably be the best foundation to start from. Just finished installing mine, so you can follow the link in my signature if you'd like to see photos.
mcb
Matt Burch
RV-7 (last 90%)
http://www.rv7blog.com
VAF #836
Any opinions expressed in this message are my own and not those of my employer.
