Old 05-26-2013, 10:33 AM
NYTOM NYTOM is offline
Question Power in connection????
All my breakers are Klixon and the line terminals are clearly marked as such but on the one breaker I have that is not a Klixon there is no marking. It's one of the high amperage one's ACS sells for the alternator. Does it matter which terminal I use as the line in? No marking I can see and I can't find any spec sheet on it. Klixon's line terminal is always on top. At least one's I have.
Tom Norwood
Classic "Short Tail 6A N822PM
TMX-O360. Phase 1
Old 05-26-2013, 01:57 PM
bird's Avatar
bird bird is offline
It should not matter, Normally the top is the line in on most electrical devices.
Bird
Bird
rv8 entire airframe at airport now, painting done, intersection and gear upper and lower fairings done, maybe order engine around first of year or before the next rate increase.
"to fly is a privilege that I am so thankful to God for"
http://www.mykitlog.com/tcb328/
Old 05-27-2013, 05:44 PM
Thumbs up
Thanks Bird. At first I thought I asked a dumb question cause you usually get a ton of answers here. I just figured since it is DC voltage and polarity is very important with DC, it might be an issue. The fact that Klixon marked line side got me wondering if I'd damage the breaker if wired backwards.
Thanks again Bird.
Tom Norwood
TMX-O360. Phase 1
