if you swap over the cutters - does the same cage still chatter ? If so it sounds like the bearing or bush is worn out. I have several that I bought on ebay - Running at 2900rpm or faster .. Never a problem with chatter if the bearing is tight - Can you wobble the shaft side to side if you push on the cutter nose ?
Jan
Slooow RV6, no hole, builder in UK
Paid up for 2015 ...
