Old 05-23-2013, 05:55 AM
LAMPSguy's Avatar
LAMPSguy LAMPSguy is offline
Default Aluminum tags alumiprep
I found some inexpensive pre-numbered valve tags online (.050 Al with # etched into it, no anodize). I was thinking of using these for parts identification while alumipreping and alodining. Will they be single use, or is it ok to put a freshly alodined small piece (size of quarter) right back into alumiprep. They are cheap enough that it wouldn't be too bad to throw away if needed or better for alumiprep longevity.
RV-? in planning stages.
RV-14 #140050 SOLD
Permanently willing to contribute fuel for RV rides
Helicopter ATP/CFI(I)
ASEL/AMEL Commercial/Inst/CFI(I)
Aerobatic Instruction available
Atlanta based.
Old 05-23-2013, 07:13 AM
PJSeipel PJSeipel is offline
I made my own out of scraps of .032 and etched numbers into them. I've been using the same set for about 10 years now with no problems. Heck, half of mine have Akzo primer on them as well since I leave them on while priming. Doesn't seem to have a negative effect on the alumiprep or alodine, although that's just my experience. Their surface area in relation to the parts you're prepping is relatively small so I doubt their effect would be much.
PJ Seipel
RV-10 #40032
