Keep VAF
Going
11-24-2011, 12:56 PM
Tip: Adapting a Roscoe Pediatric Medical Oxygen Regulator for 2 Place Aviation Use
Before we start, a few important notes.
1. You must clean all of these parts thoroughly with a water based, non flammable cleaner before attaching them to oxygen. The presence of any grease, lubricant, oil, etc can very easily start a fire. As soon as one of these easy to start items begin to burn, the metal (in the presence of pure oxygen) will start to burn too. This is not a fire you want in your cockpit!
2. If you do set yourself on fire using this info, it is not my fault. This is how I built mine. For all you know, I'm a complete moron.
OK. Disclaimers taken care of. I purchased a Roscoe Pediatric regulator and a couple of D sized Aluminum cylinders on Ebay. I looked long and hard for a medical regulator that had an NPT threaded output, but have not been able to find one. If someone does find one, please post the info!
The Roscoe has a hose barb output that attaches with a metric thread. I don't have a lathe, so I had to kludge my setup together. I removed the hose barb from the regulator and figured out what size metric thread it had.
I then bought a tap of the same size and a stainless steel metric bolt. I cut the end off of an NPT nipple and drilled and tapped the ID for the metric bolt.
I then cut the head off of the bolt and drilled a hole through the center. After a thorough cleaning, the bolt was threaded into the nipple with Teflon tape in order to make an adapter.
I used the rubber gasket that came with the barb fitting and attached the nipple to the regulator.
The last step was to add a T and a pair of oxygen safe dry break connectors from Mountain High.
I tested for leaks in a sink full of water.
I make it a point to always turn the bottle off for takeoff and landing. If the regulator and bottle are turned on, I like to always have at least one cannula attached as I don't want to risk a leak at the fittings. If a leak happens around a gasket it can create heat and that can lead to fire. Even though I don't have any leaks, the regulator was not designed to have a valve after it, so I keep a cannula attached if the gas is flowing.
Guy Prevost
Albuquerque, NM
RV-8a Built, Enjoyed, Sold
Two Kids: Built, Enjoying
RV-10, Bought, Rebuilt, Enjoying
Build / First Flight Video: http://www.youtube.com/watch?v=8f9HXzZT1dE
Arguing on the internet is like having a competition to see who can hit a brick wall the hardest. You may win, but you're still an idiot.
11-24-2011, 01:07 PM
how much did you pay for the different materials?
nothing special here...
11-24-2011, 01:31 PM
Guy,
Great tip! I'm putting this on my list of projects!
Thanks!
11-24-2011, 02:31 PM
Looks great Guy
Paul 'Bugsy' Gardetto, Col, USAF (ret)
Milwaukee, Wisconsin (Timmerman Field)
N377KG - Flying (250 hrs)
RV-7A, Aerosport O-360, WW200RV
Advanced Flight 5400
Avidyne IFD440
Paint by planeschemer.com
11-24-2011, 03:41 PM
I have the same exact regulator, which I bought on eBay for around $25. Since I have a lathe I cut the barb off the fitting and drilled a hole for a 1/8" NPT thread into the fitting itself. There's enough meat left in the fitting to run a 1/8" bottoming pipe thread tap into it. I was able to thread one of the same CPC fittings I got directly from the manufacturer at a fraction of the cost MH sells them for.
Bob Japundza CFII A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
11-25-2011, 08:40 AM
I think I paid about $20 for a pair of new bottles. The regulator was about $25. I bought the cannulas and CPC fittings from Mountain High out of convenience, but I'm sure better deals could be had elsewhere. If I remember right, the cannulas and fittings nearly doubled the cost of the system.
I also bought a transfill system that will let me fill the medical bottles or aviation bottles from a welding cylinder.
Guy Prevost
Albuquerque, NM
11-25-2011, 09:53 AM
Guy, thanks for the tip and write-up. (same to you Bob).
For the RV-8(A), where do you fix the bottle so it is reachable in flight?
11-25-2011, 04:05 PM
Thanks for the links. I read them a while back. The one thing I saw in the archives that was close to what I'm asking was a picture of a tank mounted horizontally on the back of the RV-8 pilot seat.
I'll have to test the theory. I'm not sure I'm flexible enough to open the valve once flying.
I was hoping Guy could explain his install since he was recommending "turning off the oxygen for take off and landing".
I'll install a dummy mock-up to the back of the seat and see if I can reach it.
11-25-2011, 05:12 PM
I hang mine front the crossbar behind the front seat when dual. When solo, I usually just set it in the passenger footwell. I really should secure it better for the latter case...
Guy Prevost
Albuquerque, NM
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
