Rudder Peddle Extensions
Aerosport1
Aerosport Products is going to start offering these extensions with Your Custom N-Number or whatever you would like, We will also offer a standard set with AEROSPORT on them. These are Nylon PA12 and the cost will be $75.00 per set of 2 for the Standard and for custom will be $95.00. For custom pedals allow around 2 weeks. I have been flying with a set of these that I machined out of Aluminum for 8 years. I have just changed over to the new ones. They only take about 10 minutes to install per side.
They are not on our website yet so if you would like a set please call us direct or email
http://www.aerosportproducts.com/index.htm
Someone should tell Steve Melton of the need
Someone should tell Steve Melton of the need. I assume he would have them on his daughters site right away!
Larry
We can increase the offset. let us know what you would like and we will see if that will work. 1" should be no problem. We can make these for the RV-8 peddles also.
These are the ones I just installed in my RV-10. I replaced my aluminum ones.
