Go Back   VAF Forums > RV Firewall Forward Section > Propellers
  #41
Old 01-10-2021, 12:55 PM
Flash Flash is offline
Default awesome
Originally Posted by Walt View Post
I'm in N Texas/DFW area.
Thanks Walt. I will reach out through your website!
cheers
Scott
Old 01-10-2021, 10:48 PM
GOFT GOFT is offline
[quote=gmcjetpilot;172309]Not all equip is the same and more over not all technicians and techniques are the same. The test should be done under power with the blades off the stop (constant speed prop) with the cowl installed.
"Off the stop". Does this mean prop to be pulled back as in coarse pitch?
RV-14A Flying Jul 2020, thanks to all
Old 01-23-2021, 01:49 AM
mbauer mbauer is offline
Default Helicopter AP/IA
Lost my regular AP/IA to full time work. Spent summer of 2020 on the ground trying to get a mechanic.
New AP/IA works on all the local Medvac helicopters.
Almost any helicopter mechanic can balance your prop.
Easy to see the difference. Spinner could be seen spinning in flight, now it looks like paint that is not moving/spinning.
Mine started out at 1.2ips, now .04. That after three runs lasting a total of about 20-minutes. Start/Stop/add weight.
Smooth as silk. Great investment for $200 total.
Mike
Mike Bauer
N999SN 1998 Syd Nelson RV-6 (purchased 2017)
UTC -09:00 Alaska
Old 01-23-2021, 05:57 AM
Walt's Avatar
Walt Walt is offline
[quote=GOFT;1493124]
I've heard this before but if the blades are not tracking correctly or blade angles are not the same, it will cause an aerodynamic imbalance which cannot be 'fixed' by balancing. If blade tracing is out of limits balancing is generally not possible.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
