Old 09-16-2021, 10:24 AM
HEB1022 HEB1022 is offline
Default RV-12is Foreflight Profile
Has anyone set up a aircraft profile (performance and Weight & Balance) on the is-version of the RV-12 that you would be willing to share? Send me a private message and I will give you email address to share to.
Thanks in Advance,
Harry
Old 09-16-2021, 12:01 PM
Amadeus Amadeus is offline
Default Here is what I did - not sure if it is correct.
Please advise....
Please advise....
Please advise....
Please advise....
Please advise....
Purchased N112DR E-LSA flying with 28.2 hours - Thank you David (CraftingN112DR) for putting your skills, knowledge and attention to detail in this RV-12iS!
Dropped at paint shop this morning (July 15, 2021)
Picked up from paint shop (August 14, 2021)
Donated
Old 09-16-2021, 12:10 PM
Thanks for posting! I'll take a look and let you know if I see any issues.
Thanks!!
Harry
Old 09-16-2021, 12:14 PM
Default Forgot the Performance Profile
I set up the Performance Profile to reflect the values for once cruising. This means that initial climb at take off (75kt) is not the Climb TAS displayed in the setup. I account for the fuel burn of the take off initial climb in the Aircraft section by placing 1.5 gallons for Start/Taxi/Takeoff Fuel.
Cruise at 105kt typically is 4.4 or 4.5 gph but I like to be conservative and err on the side of caution. Rather have more fuel in the tank than less than expected.
Donated
Old 09-16-2021, 12:19 PM
jrtens's Avatar
jrtens jrtens is offline
Looks like your ARMs are off a bit there.
From the POH:
Pilot 78.85
Fuel 100.83
Baggage 114.42
Jon
2019 12iS SLSA
Salt Lake Int'l
Old 09-16-2021, 12:39 PM
From the POH:
Pilot 78.85
Fuel 100.83
Baggage 114.42
Thank you. I was on a Foreflight webinar last night while doing this and forgot that I just WAG'ed, I mean estimated, the ARMs in a hurry.
Donated
Old 09-16-2021, 03:40 PM
Default Ceiling
The ceiling figure has been brought to my attention.
17,300 is correct according to the POH.
Thanks to all for looking this over.
Donated
