rmartingt
I'm hopefully going to hang the engine and start fitting the cowl in the next few weeks, so I'm trying to figure out when I need to order epoxy and other composite supplies. Will I need any resin, cloth, etc. in order to get the cowl trimmed and fitted enough to do baffle work? Or can I put that off a bit?
I want to get the baffles fitted so I can start wiring up the engine and such. I'd like to wait on the composite finishing work till later, if possible, so I can do all the composite stuff at one time.
