I have a carbon monoxide leak in my RV-12iS that I can't track down. The engine is a Rotax 912iS. It only happens on climb out with full power. When I pull the power back to ECO mode it goes away. I'm getting numbers on my Aeromedics CO detector of 15 to 30ppm.
I have checked the firewall, the cabin heat vents, the fresh air vents with no success. Also, I have not found cracks in the engine exhaust tubes per the service bulletin.
My current thought is that the CO is not coming through the firewall, but it's coming from the exhaust pipe and then leaking in through the wing seals and then through the wing spar holes. I think it only happens at full power because the engine isn't making significant CO when the throttle is pulled back into ECO mode.
Has anyone had this problem and been able to solve it?
Patrick
Patrick
