Hi All,
Is a #6 dimple die set required to build the RV-12iS? I don’t see it listed on the builder’s tool requirements in Section 3, but step 7 on page 17-04 of the KAI (revision 4), Installing Access Hatch, instructs you to dimple the screw holes in the W-1202-L Mid Wing Skin and in the VA-195H Access Hatch to install AN507-6R6 screws and K1100-06 nutplates. If it isn't required, what did you use to complete this step (i.e. the 1/8 or 3/32 dimple die set)?
Chadd
Chadd
