Has anyone else noticed the axle bolts hitting the backside of the inner main wheel bearings ?
Is it ok to flip the bolt around and put the head on the bearing side?
Should we just add washers under the head?
It looks like an AN4-16 bolt used to be specified and now the plans specify an AN4-17, which interferes!?
