Old 06-01-2021, 06:16 AM
bob865 bob865 is offline
Default k1000-6 NutPlates
Good morning VAF. A quick question I haven't been able to find an answer to through searching google and the forum. I'm finishing the right elevator on my empennage kit and when I try to thread in the rod end bearings for the hinge point, they are really tight after the first few threads. I tried the other nut plates in my bag and they are all this way. When I look at them, I can see the threads all the way through so it looks like they should be able to thread all he way through. It almost looks like the coating that on it is blocking the threads so I ran a tap through a couple. But I stopped because I am curious is this is the way it's supposed to be? Are they tight to hold a bolt like a nylock nut? or am I making a mess of things by running a tap through?
--Adam
First Time Builder
RV8A- Status:
Empennage Kit: In work (45%-ish)
Wings Kit: Ordered (Standard Build)
https://eaabuilderslog.org/?s=Adam_RV-8
Old 06-01-2021, 06:30 AM
They are supposed to be tight and you really shouldn't run a tap through them - they will lose some/most/all of their self locking feature. Use boelube or some other lubricant and the screws will go in much easier.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 06-01-2021, 06:33 AM
lr172 lr172 is offline
Yes. more char
Old 06-01-2021, 07:08 AM
I knew you guys would know! Thanks!
--Adam
First Time Builder
RV8A- Status:
Old 06-01-2021, 07:55 AM
wirejock's Avatar
wirejock wirejock is offline
Default Nutplate adjustment
If you ran a tap through and they are loose, get a pair of vice grjps and squeeze the end were the screw exits. Start with no clamping force and increase a tjny bit at a time till it barely deforms. Lock that setting and repeat on the others.
I've had a few that were so tight, I had to run a tap through then reset them to a realistic friction.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 01/01/2021, plus a little extra.
Empennage, wings, fuse, finishing kit, now FWF
Disclaimer
Old 06-01-2021, 08:29 AM
John Tierney John Tierney is offline
Do check them for threads before you rivet them on, as from time to time a nutplate sneaks by the threading machine at the factory.
John Tierney
Vonore, TN
RV-7A - N777JT Flying
Old 06-01-2021, 12:52 PM
ctennis ctennis is offline
Also keep in mind that if your nut plate opening isn't perfectly centered with the hole in the material in front of it, your threads will end up rubbing against the aluminum opening as you thread it into the nut plate, adding what can be a lot of extra resistance.
N29213 - RV8 completed 2017
N955CT - RV10 completed 2021
Columbus, IN - KBAK
