My RV 4 fuel tank sending unit was showing some staining so like a dummy I tried tightening the screws and now I have a drip. So I drained the tank and went to remove the screws on the sending unit and it appears that there are nuts on the screws and not nut plates as they just keep turning and are not backing out. So I'm thinking the fellow that built the plane did not use nut plates.
So, is it worth the effort or even possible to try and remove the big inspection panel to make my repair on the sending unit and maybe add nut plates at the same time?
Or do I bite the bullet and remove the tank to make the fix? The tanks were
removed 4 or 5 years ago and were cleaned up and resealed so I should be good on that end. It's only the sending unit that needs resealing at this stage.
Tim
Tim
