Which Slick model?
777Dave
Thought I had this figured out....no.
Replacing a Bendix mag, right side, no impulse. 0-360.
So which Slick do I need?
I have a nearly new 4373 but the shaft is too long and I assume it?s meant to take an impulse coupling.
Thanks in advance, I will be selling the 4373.
According to the ACS site, the 4373 is L/H w/ impulse, so you would need an adapter to use it. I believe you want the 4370.
I'll be pulling one off my engine soon to be replaced with a second P-Mag.
Magneto
Thanks for the reply Ray. Can you give me a reference on the 4373 adapter please? I called Champion but got voicemail.
How much time on your Slick?
