Old 10-14-2020, 07:42 PM
flymo flymo is offline
Default RV7 Elevator Pushrod
While doing some maintenance today, I heard a faint noise upon moving the stick forward / back. Turns out my RV7 forward elevator pushrod is lightly touching something as the pushrod passes it's "Low Point" of travel. I removed the center cover panel in the baggage compartment, but the contact is forward, beneath the seats / floor panels. Anyone seen this before, any fixes before I tear more into it? Thanks
Old 10-14-2020, 08:05 PM
rswalden's Avatar
rswalden rswalden is offline
Yes.... Continue to investigate.
My friend's RV-6 had a slight scraping noise between the seats when moving the stick fore and aft. After opening up the tunnel cover, flap housing and both floorboards I discovered a nutplate screw that had worn a slot in the elevator pushrod.
If something doesn't look or sound normal...investigate...
Bob Walden (Waldo), CFII-ASMEL, Commercial Glider
KFFC "Falcon RV Squadron" Peachtree City, GA
RV-7A Tip-Up, IO-390, 800+ Hours
EAA/AOPA/Vans Air Force 2021 Supporter
Old 10-14-2020, 08:41 PM
climberrn's Avatar
climberrn climberrn is offline
If I remember right, I had to open up one of the holes where the forward elevator pushrod went through a bulkhead, under the baggage area. Did it before first flight. Rubbing issues donít fix themselves.
Joel
N626JA
RV-7A at CXP
Flying!
Old 10-15-2020, 07:50 AM
I'm not a builder (yet) so I was scratching my head about how close the design has the fwd pushrod to another structure. Looks like F-705 could be the issue, floor panels coming out. Thanks
Old 10-15-2020, 09:15 AM
swisseagle's Avatar
swisseagle swisseagle is offline
Check the bulkhead at the station of the rear spar. There most builders must reduce the height of the spar carry thru a bit in height. make a shallow, big radius. This was discussed here also and VANS support told to do so also.
Dominik
RV-7A, TMX-IO-320, FM-150, Sensenich FP
Flying since 28. April 2016
Old 10-15-2020, 10:46 AM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
Default Pushrod rubbing
Here's a thread on VAF that might help you locate the issue. Easy fix.
https://vansairforce.com/community/s...ad.php?t=54390
Carlos in Arizona
EAA Chapter 538 www.chapters.eaa.org/eaa538
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 10-19-2020, 09:51 PM
Finally got the forward elevator pushrod out, it has been touching the rear spar bulkhead. I relieved some material as discussed in other threads, but am wondering if I should build a new pushrod. The rub area is a little over an inch long, and you can feel a slight flat spot. My crude calipers show about 3-4 thousandths worn away. I'll probably ask Van's as well. Thanks for the help.
(image attachment attempted)
