Old 01-24-2021, 07:56 AM
mikelupo mikelupo is offline
Hi Andrew, Just a brief follow up. I am able to get the ILS soft-key to appear once the ILS comes into radio range. I am able to get the vertical guidance indicator to appear. And...as the manual says. The AP or FD will not take any inputs from the ILS. That's a shame, because it's a very capable autopilot otherwise.
In Summary, I can hand-fly the ILS now. So I think there are no further barriers to me using my RV-10 for my instrument check-ride.
Would be cool to take a look at the source code of this unit.
Surely Bendix would never release that.
Mike
RV-10 (purchased)
Sonex builder - EAA chapter project
PA-28-181
PA-28-140
Old 01-24-2021, 10:24 AM
Rallylancer122 Rallylancer122 is offline
If either of you guys has a better manual or pilots guide for the trutrak efis ap I would love to see it. The one you can download from the website leaves a little to be desired.
Old 01-24-2021, 01:36 PM
ALagonia ALagonia is offline
Originally Posted by TruTrakAndrew View Post
You wouldn't happen to have an SL30 in the aircraft? The TruTrak ARINC converter actually emulated the SL30 interface, so if you happen to have an SL30, you could just hook that up directly to pin 30 on the TT EFIS.
Hello Andrew,
Quick question. I have the Vizion 385 and an SL30 Nav/Com in my 9. I have the AFS 4500 with their ARINC module. Can I shoot a coupled ILS with that setup? I havenít tried because I thought the Vizion 385 wouldnít couple to an ILS and have been relying on LPV approaches only.
Old 01-24-2021, 02:32 PM
vic syracuse vic syracuse is offline
Super Moderator
Originally Posted by mikelupo View Post
I have the TruTrak EFIS installed along with a Garmin 430W. I can fly GPS approaches but cannot fly any ILS approaches. I get no vertical guidance. Seems I need an ARINC 429 interface. I'm informed by Jesse Saint that the one that TruTrak manufactured is out of production for a long while now, but that's the one I'd need.
Would anyone know where I could get one or have any experiences to share that could help me?
Regards,
Mike
Did you check to see that the 430 has the vertical labels enabled?
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
Old 01-24-2021, 05:45 PM
Itís fine actually. I just didnít understand my equipment. Iím still learning!
I do get vertical guidance with the ILS but I have to hand-fly the approach.
The AP or FD take no action based on ILS inputs.
Thanks for the reply.
Mike
RV-10 (purchased)
PA-28-181
PA-28-140
Old 01-25-2021, 08:31 AM
TruTrakAndrew's Avatar
TruTrakAndrew TruTrakAndrew is offline
Originally Posted by ALagonia View Post
Hello Andrew,
That will depend on the output of the 4500. I can't recall if they were doing vertical steering for ILS approaches. The Vizion doesn't have the ability directly to do any analog approach coupling (even when it is sent digitally). It requires conversion of the deviation signal to either a fixed width course or to a vertical speed command.
Andrew Barker
Andrew.Barker(at)Honeywell.com
BendixKing / Honeywell
www.BendixKing.com
TruTrak
RV-4 214NY "Carrie Ann"
RV-10 989TS - undergoing complete overhaul!!!
Always flying someone else's airplane too
EAA - 309420
Old 01-25-2021, 09:10 AM
I think the one that Andrew referenced earlier in this thread is the last one that was published.
RV-10 (purchased)
PA-28-181
PA-28-140
Old 01-25-2021, 10:21 AM
Roy Thoma's Avatar
Roy Thoma Roy Thoma is offline
Default AFS4500 coupled ILS
I started flying N174RT with an AFS4500 (before getting the first customer AFS5600). The AFS4500 would convert the ILS signals from my SL30 or my GNS430W to ARINC signals that the AFS branded TruTrak AP used to fly fully coupled ILS approaches. I believe AFS was one of the first companies to support coupled ILS approaches like this. Suggest verifying with Rob at AFS.
Regards,
Roy
N174RT (RV-7A) first flight 5/31/11, 1780hrs as of August 2020:
Tip-up, Lycon IO-360 EXP, WW 74HRT, AFS 5600T, AF-Pilot, IFD440, SL-30, echoUAT, D100 for backup, CQ1 headsets, CMW E-Lift
Our other riveted aluminum monocoque RV is a 2012 25' Eddie Bauer Airstream
Past aluminum monocoque vehicles:
N601RT (CH601HDS) First flight 5/03, 1550hrs after flying 8 years: 912ULS, GNS430W, SL-30, D10A Sold
1995 Midnight Pearl NSX w/BBSC Sold
EAA Chapter 105 board member 2010->2015
