Old 01-22-2021, 03:08 PM
von_flyer von_flyer is offline
Default Garmin GSA28 with Ray Allen trim
I would like to verify the wiring of the GSA28 elevator A/P servo also using a Ray Allen T3-12A trim servo. Here is what I have. In addition to verifying the connections perhaps someone can tell me if the hat switch on the stick pulls an input to ground to select that direction of trim servo movement? Notice I did not draw the Cooley Hat Switch yet on terminals 11 and 12. Thank you in advance.
John von Linsowe
Michigan
RV-7
Cessna 140
Old 01-22-2021, 03:28 PM
mfleming's Avatar
mfleming mfleming is offline
This is my simplified drawing for my Garmin system. My system has a GAD 27.
Without the GAD 27 all your pin outs look correct when I compare them to my master drawing. Without a GAD 27, you will need a relay to have a second trim switch.
Michael Fleming
Joseph, OR
sagriver at icloud dot com
RV-7 Slider #74572
Started 11/2016
Empennage completed 11/2016 (sans fiberglass)
Ailerons and flaps completed 3/2017.
Wings completed 12/2017
Started on QB fuselage 01/2018
Sliding canopy mostly completed 10/2020
Wiring in progress
Donated for 2021 and so should you
Old 01-22-2021, 03:55 PM
Thank you Michael. So the hat switch does take the signal to ground, true low. I donít plan on a second trim switch so no GAD27.
I assume the GP1 input is configured in the G3X and displays the trim position.
John von Linsowe
Michigan
RV-7
Cessna 140
Old 01-22-2021, 04:01 PM
lr172 lr172 is offline
Originally Posted by von_flyer View Post
Thank you Michael. So the hat switch does take the signal to ground, true low. I don’t plan on a second trim switch so no GAD27.
No, not grounded.
Without the 27, you need 2 relays to send power, in both polarities to the the servo. The RA servo consumes an amp and you hat switch cannot handle that. The 28 goes into bypass mode when shut down and your switches / relays need to handle the full amp in this case. Also, the motor reverses by getting power in different polarities. The 28 is also looking for different polarities, when not in bypass mode.
The relay is typically activated via a low/ground on the hat switch, assuming you feed + on the other side of the relay coils.
Old 01-22-2021, 04:18 PM
Originally Posted by lr172 View Post
No, not grounded.
Are you saying 2 relays per trim axis, so a total of 4 relays for pitch and roll trim?
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
