w/a Donation
VAF on Twitter:
@VansAirForceNet
  #371
Old 07-14-2022, 11:08 PM
PEB PEB is offline
I would mark it INOP.
Originally Posted by Piper J3 View Post
For what it's worth.... if you leave a switch in place and it is inoperable... you should mark it as such... "IN OP"
PEB
RV-12iS
Experimental
Denmark
Old 07-14-2022, 11:09 PM
PEB PEB is offline
Yes. i reversed my switch from the start.
Originally Posted by jnorris View Post
Has anyone moved their flap switch from the center console to the panel? And/or, has anyone reversed the switch so that switch up is flaps up, and switch down is flaps down? The position and orientation of the switch drives me crazy!
PEB
RV-12iS
Experimental
Denmark
Old 11-20-2022, 05:46 PM
edmondthx1138's Avatar
edmondthx1138 edmondthx1138 is offline
I removed the factory switch and replaced it with a double throw sustained (non-momentary) switch and relocated it to the front panel.
Much easier to use and access. It also freed up the center for an armrest console that I built.
Click image for larger version
Old 01-28-2023, 06:37 PM
j4cbo j4cbo is offline
Has anyone installed the F-12132 headset brackets from the 12iS on a legacy 12? Seems like they'd be handy.
Old 02-03-2023, 10:06 AM
GatorsR1's Avatar
GatorsR1 GatorsR1 is offline
Default EZPZ
A buddy gave me a pair of the F-12132 headset brackets. Took me awhile to figure out where to mount them in my classic 12.
I was investigating the 12iS KAI to see what it would take to add the egress handle to my build. I happened to notice the brackets on Page 29iS/U-08 (rev 1) in SECTION 29iS/U: FWD UPPER FUSELAGE.
Easy install - identify & drill out two rivets, bracket holes line up, pull two new rivets.
The only "issue" is that I have dual screens (no map box). So on the passenger side, the clearance between the bracket and the under panel map tray is a little tight but hanging the headset (at least my DC's) is doable.
Bob Costello
RV12 dream machine #120764
Support VAF - if you read it, buy it!
Old 02-22-2023, 10:21 AM
seagull seagull is offline
Default A Simple Vent Handle
I added handles to my vents to make them easier to grip. The removable spark plug caps came in handy.
More info at; http://waltsrv12.com/airframe/a-simple-vent-handle/
Attachment 38726
Live as if you were to die tomorrow. Learn as if you were to live forever.
visit my blog - http://waltsrv12.com
-- Walt --
