w/a Donation
VAF on Twitter:
@VansAirForceNet
Old 05-25-2023, 03:23 PM
Jcurry Jcurry is offline
Default Legacy RV12 Fuel Line Question
Hello All,
I have the 912 ULS. I would like to replace the aluminum hard line (F-1259C) that goes from the Floscan to the firewall. I was think about going back with flexible hose.
Can you buy these anywhere pre-made in either flex hose or aluminum tubing?
Jack
Titusville, Fl
Already flying 2011 RV12 N214LA
My youtube channel: Southern Latitudes Sport Aviation
https://youtube.com/@SouthernLatitudesAviation
Old 05-25-2023, 05:43 PM
Bob Y Bob Y is offline
Aircraft Specialty can make any configuration you want.
https://www.aircraftspecialty.com/ki...ses/hoses.html
Bob Y - builder 12iS
N569TT first flight 2/9/2020
#121047
Old 05-28-2023, 01:08 PM
funflying funflying is offline
I worked with TS Flighlines to create a flex line from the Flo-scan to the firewall. We did a number of back and forth with fittings and hose length until we got a correct fit. Check with Tom or Steve to see if the information about my hose might be in their records.
Patrick Claar
Arvada, CO BJC
RV12, #401, Flying 2013, N612PC
RV6, 1996-2010 sold
Old 05-28-2023, 07:29 PM
Thanks. I'll do that.
Jack
Titusville, Fl
Old 05-29-2023, 07:38 AM
Patrick,
They are showing a -6, straight fittings and straight hose, 8.75 flare to flare. They are showing one order from you. Does this sound correct? Thanks very much.
Jack
Titusville, Fl
Old 05-29-2023, 03:50 PM
Jack,
We tried a number of fittings, straight on one end and 45 on the other, trying to find some combination to ease the insulation from the original bent rigid fuel line. I can check my records tomorrow and see if I have notes. Also I likely have a photo somewhere to check.
Patrick Claar
Arvada, CO BJC
RV6, 1996-2010 sold
Old 05-30-2023, 04:38 AM
Default Thank you
Jack,
Hi Patrick,
I have the line on order. Don't worry about checking records. I appreciate you replying to my post and offering me a solution. BTW, Tom with TS Flightlines was awesome to work with!
Jack
Titusville, Fl
Old 05-31-2023, 03:33 PM
rtlongdon's Avatar
rtlongdon rtlongdon is offline
Default Curious
Out of curiosity, why are you replacing the rigid line with flexible? Thanks.
Russ Longdon
RV-12, N712WE (purchased flying)
KAWO
Old 05-31-2023, 06:48 PM
HelIo, I did not build my plane and it has had several owners prior to me buying it. While complying with the condition inspection, I noticed that the rigid line was bulging below one of the sleeves/collar. In my opinion, this line should have been remade. The tubing looks stressed and I was concerned that this was a potential failure point.
I ordered the flex line out of convenience and I'm glad I did as it was painless to get from TS Flightlines.
Jack
Titusville, Fl
Old 06-01-2023, 10:59 AM
rtlongdon's Avatar
Thank you.
Russ Longdon
KAWO
