w/a Donation
VAF on Twitter:
@VansAirForceNet
  #11
Old 05-22-2023, 09:17 AM
Piper J3's Avatar
Piper J3 Piper J3 is offline
I'm going to fly again on Weds. Maybe I'll cover the tach with a sticky note and give it go. Could be I'm letting the best in life past me by....
Jim Stricker - EAA #499867
PPL/ASEL 1970 - Sport Pilot since 2007
80 hrs Flying Aeronca Chief 11AC N86203
1130 hrs Flying 46 Piper J-3 Cub N6841H
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 850
LSRM-A Certificate 2016 for RV-12 N633CM
Special Thanks... EJ Trucks - USN Crew Chief A-4 Skyhawk
MJ Stricker (Father - CFI) - USAAF 1st Lt. Captain B-17H
Old 05-22-2023, 11:00 AM
Mel's Avatar
Mel Mel is offline
I wouldn't cover the tach. It's still a good reference.
It's just that the MP reacts more quickly.
Mel Asberry, DAR since the last century. Over 1,100 certifications accomplished. Discount for Veterans, Law Enforcement, Fire Fighters.
EAA Flight Advisor/Tech Counselor, Friend of the RV-1, Lifetime EAA.
Recipient of EAA Tony Bingelis Award and Wright Brothers Master Pilot Award
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 05-22-2023, 11:23 AM
uk_figs's Avatar
uk_figs uk_figs is offline
Originally Posted by Mel View Post
Manifold pressure is handy for setting power. When changing power settings, RPM takes a while to settle down. Once you are used to your airplane, you can adjust power by using MAP much faster.
Mel
Is there a chart for the 0-360? I have never really looked at MP as I thought it was not relevant with a FP prop. Learn something new every day.
Figs
Dave (Figs) (RV-7 N256F, Flying)
Dave's RV-7 Blog
Email me
Old 05-22-2023, 11:40 AM
Sam Buchanan's Avatar
been here awhile
There is the old rule of thumb:
24 square = 75% power
The application is any combination of rpm and map the adds up to 48 is 75% power.
No doubt an engine-appropriate chart will refine that rule but it might be a starting point in absence of a chart.
Sam Buchanan
RV-6
Old 05-22-2023, 11:44 AM
bbaggerman bbaggerman is offline
Default MAP pressures for 912 ULS
You can still set power faster with MAP than with RPM. MAP is definitely useful with F/P prop. I flew my RV-6 with F/P for over 25 years making power adjustments with MAP.
On my RV-12 a previous owner installed a 3-bladed Whirlwind prop. I understand the 3-bladed prop is supposed to be smoother and quieter. I don't have any experience with the 2-bladed standard version so I am not sure of the pros and cons.
One of my issues with this prop is that since it was installed it was setup such that on the ground WOT results in 4900 RPM. I think that is lower than the usual 5200-ish that you get with a standard prop. Takeoff performance is great and it doesn't have any problem reaching higher RPMs in flight so I am disinclined to try to adjust it. So my quandary has been how to set power. With a standard prop high cruise is 5500 RPM and low cruise is 5000 RPM. But 5500 RPM "seems" too high for me. Fuel flow, MAP, and air speed all seem higher than expected.
My approach then has been to look at MAP pressure rather than RPM for setting power. Like Mel, my experience has also been that it is easier and quicker to set power using MAP rather than RPM.
Which raises another question I've been meaning to post. What MAP do you get with a standard 2-bladed prop setup by the book? What pressures do you see at 5000 and 5500 RPM? The Mooney I used to fly was very happy at 23" but the Rotax seems to want to run higher. If I don't exceed 5500 RPM any idea what max continuous MAP is for the 912 ULS?
Bob Baggerman
Niceville, FL
N233VA
Old 05-22-2023, 11:56 AM
Tommy123 Tommy123 is offline
MAP with a fixed pitch sort of like RPM in a car with a automatic transmission but it still does tell you something. Mel is correct, MAP is quicker and isn't flopping around like RPM can do.
Old 05-22-2023, 11:57 PM
seagull seagull is online now
Does this rule apply with a geared engine? The 912ULS is 2.43 to 1.
I use RPM in the -12, I find the resolution to be more precise changing only 10 - 20 (engine) RPM than trying to set .1 of manifold pressure. Actually it is 2.43 times more precise than using propeller rpm on non-geared engines.
In the 172 I use manifold pressure because it is more precise than propeller (engine) RPM.
Live as if you were to die tomorrow. Learn as if you were to live forever.
visit my blog - http://waltsrv12.com
-- Walt --
Old 05-23-2023, 04:42 AM
Amadeus's Avatar
Amadeus Amadeus is offline
Of course not.
Sam Buchanan was replying to the question from uk_figs asking for a chart for the O-360.
Jayson
RV-12iS
E-LSA
“Never feel sorry for a man who owns a plane.” -Charles Morse (Anthony Hopkins) Movie - "The Edge" https://youtu.be/dJD0lB4zRes
"...except during the month of Annual Condition Inspection." -Me (in the hangar)
"My first wife didn't like airplanes." - Gordon Baxter
Old 05-23-2023, 08:45 AM
bobnoffs bobnoffs is online now
well.....lets get to the elephant in the room since it brought up the original question. what map numbers for the 12?
Bob Noffs
n. wi.
dakota hawk/jab 3300 built and flying. sold 6/18.getting serious about the 12. in the hangar now as of 10/15/19
RV-12 kit as of 9/13
RV-12 airworthiness cert. 11/30/2021
first flight 7/25/2022
Old 05-23-2023, 09:24 AM
Originally Posted by Amadeus View Post
Of course not.
sorry, being the -12 forum, I assumed
-- Walt --
