w/a Donation
VAF on Twitter:
@VansAirForceNet
Old 05-19-2023, 10:21 AM
Geezeravi8tor Geezeravi8tor is offline
Default fuses
Bought a completed RV-12 with color coded, plug in fuses on the front of the instrument panel as seen on most 12s. I had to replace one 3 amp fuse from the rack of spares inside my glove box. I'd like to buy a replacement spare but can't find a source -- not even Spruce. And, btw, what does one call this type fuse?
Old 05-19-2023, 10:39 AM
Isaac's Avatar
Isaac Isaac is offline
Default RE: Replacement fuse.
Most likely it is one like this:
https://www.steinair.com/product-cat...ection/page/5/
Can also be found at AutoZone, Napa, Oreily etc. auto parts stores.
___________
James D.
RV6 N947J
Old 05-19-2023, 10:40 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Probably ATO fuse. Auto parts store has them. Could be ATM or ATC.
Take one with you and go see your friendly NAPA dealer.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 05-19-2023, 11:06 AM
Mich48041 Mich48041 is offline
You want ATO or ATC lighted fuses. The "O" stands for open. The "C" stands for closed.
If your local auto parts store does not sell the lighted fuses, Vans Aircraft does.
Van's Part number for 3 amp ATC fuse that lights when blown: ES-00203
Joe Gores
RV-12 Flying
Old 05-20-2023, 11:07 PM
Default Fuses
Thanks gents. I'm off to O'Reilly's.
Old 05-20-2023, 11:10 PM
Thanks all. I'll try my nearby O'Reilly's.
Old 05-21-2023, 03:24 AM
Piper J3's Avatar
Piper J3 Piper J3 is offline
Yes, but you really want to replace with the lighted fuses as originally supplied by Vans. Fuse illuminates internal LED to indicate "open". This is very good safety feature and should be adhered to....
Jim Stricker - EAA #499867
PPL/ASEL 1970 - Sport Pilot since 2007
80 hrs Flying Aeronca Chief 11AC N86203
1130 hrs Flying 46 Piper J-3 Cub N6841H
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 850
LSRM-A Certificate 2016 for RV-12 N633CM
Special Thanks... EJ Trucks - USN Crew Chief A-4 Skyhawk
MJ Stricker (Father - CFI) - USAAF 1st Lt. Captain B-17H
Old 05-25-2023, 07:26 PM
CTCole CTCole is offline
I think what you're looking for is ES-00203 at Van's. Costs $1.25. It's the kind that lights up when it fails. I just ordered one yesterday.
--CT Cole
RV-12iS in progress
Old 05-26-2023, 03:04 PM
FlyingSquirrel's Avatar
FlyingSquirrel FlyingSquirrel is offline
Default Let Fuses
SteinAir sells these. You can find them here.
https://www.steinair.com/product/3-a...violet-5-pack/
Joshua Swenson
Senior Manager,
SteinAir Inc.
