w/a Donation
VAF on Twitter:
@VansAirForceNet
  #41
Old 05-24-2023, 04:52 PM
jrtens's Avatar
jrtens jrtens is offline
Glad it worked out!
Click image for larger version
Name:	Happy camper.jpg
Jon
2019 12iS SLSA
KAWO
Old 05-27-2023, 10:34 PM
RFSchaller RFSchaller is offline
Great idea to use a left hand bit. I wouldn’t have thought of that. I’ll remember that if I ever have a similar issue.
Old 05-28-2023, 05:41 AM
BillL's Avatar
BillL BillL is offline
Jeff, Excellent result. Happy to see that stud in the light.
Your grin says it all . . . .
Bill
RV-7
Old 05-31-2023, 05:05 PM
Tony_T's Avatar
Tony_T Tony_T is offline
Exclamation Nm vs. Ft-lb.
Originally Posted by Jeff Vaughan View Post
Maybe it broke in place and then backed out. Ok now to put it back with Blue Loctite and 44 lbs of torque.
[/url]
Please be careful. The spec of 44 Newton meters is not the same as Ft-lb. The spec in Ft-lb is 30 Ft-lb.! 44 Ft-lb of torque would badly over torque the bolt.
Tony
RV-12 ULS
Old Yesterday, 06:45 AM
Jeff Vaughan's Avatar
Jeff Vaughan Jeff Vaughan is offline
Default Rotax Spec
JUST TO BE CLEAR. The Rotax spec is 60 nm and 44 ft lbs with Loctite 243
Jeff Vaughan
RV 12 N237VW ELSA
Northwing Navajo Trike N561VW
RV 7A N561EV Sold
West Chester Pa
2023 donation current
Old Yesterday, 07:31 AM
Tony_T's Avatar
Ok, thank you for the heads up, I will look for the Rotax specs.
Tony
RV-12 ULS
