Keep VAF
Going
w/a Donation
VAF on Twitter:
@VansAirForceNet
04-30-2023, 05:12 PM
Regardless of which brand ANR you choose…. A lot of us folks are up in age and wear hearing aids. See this thread which might be helpful…. https://vansairforce.net/community/s...t=hearing+aids
Jim Stricker - EAA #499867
PPL/ASEL 1970 - Sport Pilot since 2007
80 hrs Flying Aeronca Chief 11AC N86203
1130 hrs Flying 46 Piper J-3 Cub N6841H
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 850
LSRM-A Certificate 2016 for RV-12 N633CM
Special Thanks... EJ Trucks - USN Crew Chief A-4 Skyhawk
MJ Stricker (Father - CFI) - USAAF 1st Lt. Captain B-17H
04-30-2023, 06:55 PM
I've been using Bose A20s for years. They work OK, no complaints. If I was buying now… No question I would buy the Delta Zulu's over the Bose A30. Significantly cheaper, equivalent noise reduction, comfortable, built in carbon monoxide detector.
RV-9A, 2011, bought flying
04-30-2023, 06:57 PM
The best advice I can give you is to fly with a few different headsets because not everybody likes the Bose and not everybody can notice the difference between a less expensive DC or LightSpeed and the more expensive Bose. You might end up choosing your next headset by how it feels on your head and not by the hype, advertising, or price.
Up to a couple of months ago the Bose A20 was the Gold Standard for a big chunk of pilots. Just because the A30 came out didn't suddenly make the A20 not work.
Having said that, unless you're the type that needs to have the latest and greatest, and you replace your iPhone and iPad every year with the latest one, take advantage of the A30 hype and buy some cheaper A20s !
Sadly sold my RV-8 however still trying to enjoy life by living on my airport with FREE campsites & facilities for ALL visiting pilots to enjoy www.facebook.com/VacaMooAirport/ while my next airplane recently purchased finally arrives !!!!
Exempt by 3 out of the 10 ways but I still donated.
04-30-2023, 08:19 PM
I fly a light sport airplane powered by a 912 ULS. I own both a BOSE A20 and a DC ONE-X (both over the ear, both ANR). I use both regularly and I can barely tell any difference in comfort or noise reduction. Both headsets are very comfortable and both have excellent noise reduction.
04-30-2023, 08:48 PM
Originally Posted by todehnal
In doing a bit more research, it seems that Rotax powered aircraft don't get along that well with ANR headsets due to the higher frequencies generated by these high RPM engines.
ROTAX included a new Bose A20 headset in the engine crate that came with my RV-12iS kit. Sure hope they get along well with the engine 🤞.
Larry New
RV-7A - Built, flew 1000 hrs, 48 States in 7 Days, sold
RV-10 - Built, flying 500+ hrs
RV-Pedal Plane - Built, grandkids flying
RV-12iS - Building, empennage
VAF on Annual Autopay
04-30-2023, 09:23 PM
Just a quick warning about headsets. I had some old mono headsets that I like real well when I bought my -12. Don’t use mono headsets with the Flightcom 403 that comes standard. A mono headset will sound horrible for a while and then the intercom will fail. Ask me how I know.  This info is in the Flightcom manual but they don’t make it obvious.
Bob Baggerman
Niceville, FL
N233VA
04-30-2023, 11:04 PM
What's the source on this?
05-01-2023, 06:13 AM
You might want to consider these: https://cqheadset.com/about-us/
I have been using them for 3 or 4 years and like them a lot. My airplane (Wittman Tailwind W10) is relatively noisy and these work very well. I personally think they are as effective as most ANR sets and certainly avoid having the "clamp" over your head. I originally did not think I could use them as my ear canals are small and I did not like anything in my ear. But after using the smaller ear tips (beige colored), it has not been a problem and they are very comfortable over long trips and for me are just as quiet as other headsets (including ANR) that I have used.
The speaker/sound quality is good with stereo and Bluetooth supported, and the mic quality is also good. As others have said, "it is a personal preference" but I am completely sold on the above headset. Not to mention they are a supporter of this forum and fly an RV.
Keith
Keith in Lacrosse WI area
Finished Wittman Tailwind in 2016
Flew RV9A and RV6a while building
lurking for years but now paid
05-01-2023, 06:15 AM
Originally Posted by larrynew
ROTAX included a new Bose A20 headset in the engine crate that came with my RV-12iS kit. Sure hope they get along well with the engine .
Did you purchase “Rotax Care” (extended warranty) with the power plant?
I did, and expect the Bose headset to be included. That made the deal for me.
BTW, my light speed ANRs work great in both the 12 and the 12iS. I don’t understand some of the below comments. (I have sensitive musician ears…)
Donation 2023 paid
ASEL INST COMM Tail-wheeler
RV-12iS builder (Empennage complete, Wings complete!, Fuselage well under way!, finish kit under way!, Garmin avionics under way!, engine ordered, shop out of order )
Got a hangar, and moved some large pieces in!
https://eaabuilderslog.org/?blproject&proj=7buPHH99v
05-01-2023, 06:42 AM
Spending $1200 each has given me pause. Hopefully I can get some ANR users thoughts before making a huge investment. I appreciate any feedback. Thanks.......Tom
Your best bet is to pickup a used A20 off eBay. A lot more people are dumping the A20, looking to "upgrade" to A30. The ANR is equivalent. I picked up TWO used A20's 2 years ago for about $650 each. There is nothing wrong with an A20 though today.
I feel its true that they don't do as good of a job on a Rotax as a dinosaur engine..and personally, I believe a mfg could do a better job with a Rotax-specific headset.. but it is what it is.. and they aren't bad at all..
Rob Carsey, Winfield Park, NJ
RV-12iS (N713) / Completed 12/2020 / 350hrs and counting
ASEL, Glider, AGI/IGI, LSRM-I, FCC GROL
APRS Track or ADSBExchange Track
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
