w/a Donation
VAF on Twitter:
@VansAirForceNet
  #11
Old 05-01-2023, 06:18 AM
Bill==You are right on the timing----as I recall. Not to call out any OE's, but Chrysler products, expecially Dodge trucks during the early to mid 2000's were notorious for heater core leaks. Yep---major surgery in the cabin to R&R them-along with the evacutating the A/C system. You could look into the inlet/exit tubes and see the aluminum pitting from the Dexcool. Similar with the 'plastic' tanks. We may be seeing something similar here.
Tom
RV7A Tail Kit Completed, Fuse started-Pay as I go Plan, on hold while we develop new products for RV builders
Ridgeland, SC
Old 05-01-2023, 03:23 PM
Amadeus's Avatar
Amadeus Amadeus is offline
Close monitoring of the return of liquid after blowing dry indicates the issue is in a one-and-a-quarter inch section of the lowest row of fins.
I've ordered a new batch of Marine-Tex and plan to empty the cooling system, blow the radiator dry then clean it with denatured alcohol. Once completely dry I will hold a stop block on the back of the radiator and push Marine-Tex into that single row within the one-and-a-quarter inch section as tightly packed as I can get it. Once cured I will refill the cooling system an watch for leaks.
Jayson
RV-12iS
E-LSA
“Never feel sorry for a man who owns a plane.” -Charles Morse (Anthony Hopkins) Movie - "The Edge" https://youtu.be/dJD0lB4zRes
"...except during the month of Annual Condition Inspection." -Me (in the hangar)
"My first wife didn't like airplanes." - Gordon Baxter
Old 05-01-2023, 03:30 PM
BillL's Avatar
BillL BillL is offline
Remember that aluminum forms an oxide on the surface that hinders adhesion. You should consider using some metal-prep with phosphoric acid to clean that area. We use it all the time to prep for alodine and paint. Metal-prop, rinse with water and then alcohol to remove the water.
Bill
RV-7
Old 05-01-2023, 03:32 PM
Amadeus's Avatar
Thank you. Had not considered this.
Jayson
RV-12iS
E-LSA
