w/a Donation
VAF on Twitter:
@VansAirForceNet
  #21
Old 03-17-2023, 12:08 PM
rtlongdon's Avatar
rtlongdon rtlongdon is offline
Balancing it might be a PITA as the stabilator control cables need to be removed so there is no outside influence on the balance. I'd question how much work you are really saving. It's not terribly hard to pull the stab off IMO.
That being said, usually stuff like this arrives at the same amount of work, just with effort put into different tasks. I pulled my stab and also changed/loctited the bearings and had a great opportunity to inspect a lot of things that are normally not easy to see. Cheers!
Russ Longdon
RV-12, N712WE (purchased flying)
KAWO
Old 03-17-2023, 01:57 PM
seagull seagull is offline
The control stick because of its off center pivot loads the control to down elevator. With the cables connected you won’t be able to neutral balance the stabilator. The cables can be removed from the rear outside then go inside to remove the counter balance. You will need several in / out attempts to get the balance correct. In my opinion if you are at the point of removing the tail covers and cables you are only 15 minutes from having the whole assembly off the plane, especially if you have a helper.
Live as if you were to die tomorrow. Learn as if you were to live forever.
visit my blog - http://waltsrv12.com
-- Walt --
Old 03-17-2023, 02:06 PM
I was planning on doing mine from inside but after reading a few reviews decided to do it from outside. I removed the assembly by myself and had a helper to balance and reinstall. The balancing was done by hanging it, not on the plane which was quick and easy.
-- Walt --
Old 03-17-2023, 02:22 PM
D&M Dan D&M Dan is offline
Can someone tell me where to access 12I KIA Page U-11?
RV12 Flying
N930DD
Home Field KSDC
Old 03-17-2023, 04:05 PM
https://www.vansaircraft.com/service...isions/11is-u/
Balance procedure is on page 11.
-- Walt --
Old 03-18-2023, 05:34 AM
Thanks, completely missed it.
RV12 Flying
N930DD
Home Field KSDC
Old 05-02-2023, 09:03 AM
Mich48041 Mich48041 is offline
It is not necessary to reinstall the stabilator to check its balance.
Instead, hang the stabilator with cord attached to the pivot bolts.
The calculated weight to remove was 448 grams. But the stabilator was
balanced after removing only 400g of lead. The total length of lead removed was 74mm.
The horizontal cord in the picture is holding the AST trim tab up.
The aft end of the AST PUSHROD is resting on bolt per plans page 11iS/U-11.
I will suspend the forward end of the AST PUSHROD with cord for more accurate balancing.
Click image for larger version
Joe Gores
RV-12 Flying
Old 05-02-2023, 03:31 PM
I suspended mine from the pivots off the plane for balancing also. I used a postal gram scale to weigh the end of the AST pushrod,then used tire weights of the same weight taped to the AST horn to simulate the AST pushrod.
-- Walt --
Old 05-05-2023, 02:23 PM
gossend gossend is offline
So I'm still not understanding why balance is so critical. Any response from the Mothership That I might have missed??
Dick Gossen
gossend@gmail.com
Flying: EAB RV-12 with 130 HP UL Power 350is engine. Call me so I can brag about it!.....or get you a discount on a new one of your own
408 499 8587
Old 05-05-2023, 04:23 PM
hevansrv7a's Avatar
hevansrv7a hevansrv7a is offline
Question Is it necessary?
It’s a LSA which thus closely conforms and is not just EAB.
Q1: can owner decide it’s not necessary? Van’s did not call it optional.
Q2: if yes then is necessary to go back to phase one?
H. Evan's RV-7A N17HH sold at 268+ hours
Bought N512RV (RV-12)
We can lift ourselves out of ignorance, we can find ourselves as creatures of excellence and intelligence and skill. We can be free! We can learn to fly!" -J.L. Seagull
Paid $25.00 "dues" 2022.
my website
