w/a Donation
VAF on Twitter:
@VansAirForceNet
  #11
Old 03-11-2023, 07:44 PM
Bob Y Bob Y is offline
And my friend used a sharp screwdriver and hammer to easily pop one of his off. He used slow-curing JB Weld.
Bob Y - builder 12iS
N569TT first flight 2/9/2020
#121047
Old 03-11-2023, 09:39 PM
Tony_T's Avatar
Tony_T Tony_T is offline
Originally Posted by seagull View Post
De-bonding epoxy in a place like this is a non-issue, a few seconds with a hot soldering iron on the washer and it will come apart. Regular epoxy will release at about 200f and JB Weld at 400f. Soldering iron tips are around 650f so once the heat transfers from the washer through the glue line to the base metal it releases.
That's good to know. But we've been using glue, or in some cases epoxy, for years. Nothing new there. SL-00068 promises to be an upgrade to make servicing the stab less frustrating.
I did use JB to hold the washers last time but I think the shims installed per the SL is a better solution, especially used in combination with a stab service cart.
Contributing to the frustration though is the problem of handling the bulky stabilator off and then back on the airplane while fitting the mounting bolts. We have 3 RV12's here, possibly a fourth, and one building so I made up a stab service cart to make all this upcoming work much less frustrating.
I borrowed the idea from someone else and anyone is free to copy.
Click image for larger version
ID:	39546  Click image for larger version
Tony
RV-12 ULS
Old 03-11-2023, 10:13 PM
seagull seagull is offline
I used the same cart with blankets to do the SB on mine. I figured that since this was the first time removing the stab in 1100 hrs that if the next time was 2200 hrs it wasn't worth making a special fixture.
Live as if you were to die tomorrow. Learn as if you were to live forever.
visit my blog - http://waltsrv12.com
-- Walt --
Old 05-22-2023, 06:32 PM
Tony_T's Avatar
How goes it photos for the RV12 classic; not iS which has differing structure:
Drilling rivets out top and bottom, 12 in all.
Shims tapered, countersunk, dimpled as required, riveted and primed.
Brackets ready to bolt back onto the stab:
ID:	42795  Click image for larger version
ID:	42796  Click image for larger version
Tony
RV-12 ULS
Old 05-25-2023, 11:13 AM
Tony_T's Avatar
Removed and reinstalled the stabilator 3 times during the balance procedure and I can report that having the shim spacer kit installed made the tasks go easier without concern of displacing washers. If there is a need to remove the stab for a SB, painting or other reason one should consider doing the SL00068 shim kit.
Tony
RV-12 ULS
