w/a Donation
VAF on Twitter:
@VansAirForceNet
Old 05-18-2023, 05:47 PM
Gandalf Gandalf is offline
Default 37-07 Fuel Neck and Sealant
I have my fuel tank and air vent in on a temporary basis. Now I am working on the fuel neck. Everything looks good except a very large gap between the flat flange on the fuel neck and the curved fuselage skin. It is my understanding that the sealant is used to close this large gap, correct?
Edit: Re-reading the instructions, I am to "bend the flange" to match the aircraft skin. I guess I will try with a vise and vise grips unless someone else can chime in with what they used.
Jeff
Old 05-18-2023, 09:09 PM
12vaitor 12vaitor is offline
You can bend the flat flange to match the curve of the skin. The fit was close enough to use a gasket to make removal easier than using a lot of sealant on the flange/skin surface. I did run a small bead of sealant around the recess created by the pipe-skin contact area (inside the pipe flange).
John Salak
RV-12 N896HS
Name:	RV12 Fuel Pipe.JPG
Old 05-18-2023, 10:10 PM
rv9builder rv9builder is offline
That looks nice, John! How did you get the pipe to be so shiny?
Mark
RV-12iS Fuselage
RV-9A Project: Sold
VAF donation made for 2023
Old 05-18-2023, 10:32 PM
John Salak
RV-12 N896HS
Thanks for the ideas and photo!
Jeff
Old 05-19-2023, 10:49 AM
Polished on a buffing wheel with red rouge to a mirror finish and then powder coated with gloss clear.
John Salak
RV-12 N896HS
Old 05-19-2023, 12:01 PM
DHeal DHeal is offline
I slightly bent the flange to approximate the curvature of the skin. I placed a piece of Saran Wrap (or equivalent release agent) on the inside of the skin at the flange/skin interface. Then I loosely installed the flange using a good bead of seml-flexible/fuel-tolerant sealant on the flange face. Don't fully tighten the screws until the sealant has cured and the Saran Wrap has been removed. This has worked well for me. Whatever you do, do not permanently adhere the flange to the skin -- one day you may have to separate the two.
David Heal - Windsor, CA (near Santa Rosa)
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since Feb 2014 - 1,290+ hours (as of May 2023)!
VAF donation through June 2023.
Old 05-19-2023, 01:18 PM
Thanks for the advice.
Looking forward to installing the canopy next.
Jeff
Old 05-19-2023, 02:13 PM
Thanks, John!
Mark
RV-12iS Fuselage
RV-9A Project: Sold
