Go Back   VAF Forums > Avionics / Interiors / Fiberglass > Glass Cockpit
Old 02-06-2021, 04:30 AM
lucaperazzolli's Avatar
lucaperazzolli lucaperazzolli is offline
Default Garmin G3X Touch DataLogs download and management
As you know the data download gives you a .csv file that's viewable via Excel.
I usually love the graphic opportunity to use the SavvyAviation website and upload files as I do with my UBG-16 monitor without any issues.
Today I tried to upload a brand new G3X Touch data log (only two flights) into the same website but it returned me an error saying "Log Data: list index out of range".
Do you use any other graphic software to see the Garmin Data?
have you any idea about ?
Luke
Trento, northern Italy
RV-8 QuickBuild, Catto 3 blade Prop, YO-360-A1A. Status : I-LUKE is Flying - 400 h. and counting
http://www.rv8.it
CrewRV8 team leader
https://youtu.be/VhAkhuqZMQA
https://www.youtube.com/watch?v=he9AFHRO1OY
=VAF= 2021
Old 02-06-2021, 06:58 AM
salty salty is offline
I’ve gotten errors from savvy before right after they upgrade their software. Ping them about it, they usually have it working next day but they might not know there’s an issue if you don’t tell them.
Old 02-06-2021, 07:12 AM
Longez's Avatar
Longez Longez is offline
Post
Hi Luke,
I upload all of my G3X Touch flights into my free FlyGarmin logbook. I have used Savvy in the past, and it should work, but find the FlyGarmin logbook the best for my needs.
Not only does it allow you to graph all your engine parameters, but also shows the primary flight display complete with airspeed/altitude/attitude and autopilot/flight director modes used on the flight.
Steve
Old 02-06-2021, 07:56 AM
Ferdara Ferdara is offline
I have uploaded 100's of flights I uploaded to Savvy from my G3x, all no issues. If you have short log, turned the g3x on the ground for a few mins and then turned it off, it will come back as an error. Look at the file size it is usually very very small. (I like getting my "Report Card", from Savvy)
Mark
Ferdara Mark Hubbard
KLFT - Lafayette LA
N596RV - RV9A
#SunShine2020
Old 02-06-2021, 01:55 PM
Thermos's Avatar
Thermos Thermos is offline
Luca,
Did you open and close/save the G3x log file in Excel before you tried uploading it to the Savvy website? I did, and even though I didn't change the file at all, the Savvy file reader wouldn't process it. I copied a fresh version of the log from the SD card and it uploaded correctly.
If that's not what you did, disregard this message!
HTH
Dave
Dave Setser
CFII/MEI
EAA Technical Counselor
RV-7 N701ED FLYING!
Nashua, NH (KASH)
Old 02-06-2021, 09:14 PM
n982sx n982sx is offline
Originally Posted by Thermos View Post
Luca,
Yes to this. Savvy reads the G3x .csv file directly and will not read the .csv file if saved from Excel.
I've never had any issues with Savvy uploads.
Bob Meyers
Built and Flying RV-14A N626KM SN 140093 http://n626km.com
Built and Flying Sonex N982SX http://n982sx.com
Old 02-07-2021, 04:18 AM
Thank you for your help, unfortunately, it does not work.
Iím speaking about a brand new G3X installed, .csv file untouched and imported directly from the SD Card (no excel or other software opening). SD card is formatted as per standard MS-DOS (FAT32). Iíve tried with two different SD card formatted with different computers (Windows OS and Mac OSX)
I tried multiple combinations of computers, browsers, and software (Savvy Analysis / Fly Garmin and CloudAhoy).
The response is: unable to upload, unable to upload check formatting (Firefox browser).
If you are curious to check my original file here :
https://we.tl/t-ZZAWhsqpjp
itís 30Mb
I love to make it runs, it helps me a lot in the flytest work.
Iíll continue the tribulation
ArghÖ..
Luke
http://www.rv8.it
CrewRV8 team leader
=VAF= 2021
Old 02-07-2021, 07:43 AM
Longez's Avatar
Post
I’m speaking about a brand new G3X installed, .csv file untouched and imported directly from the SD Card (no excel or other software opening). SD card is formatted as per standard MS-DOS (FAT32). I’ve tried with two different SD card formatted with different computers (Windows OS and Mac OSX)
it’s 30Mb
I’ll continue the tribulation
Argh…..
Luke,
That file will never work.
Instead of flying with an SD card inserted in the display and collecting individual flight files to the card as you fly, you appear to have flown, and then gone into configuration mode and exported the data stored within the display internal memory to one big file on an SD card by using this "Copy to SD Card" button.
NEVER use that button.
Click image for larger version
Name:	Data Log Config.png
Enable SD card data logging and go fly with an SD card installed and try uploading these new flight specific files to Savvy or FlyGarmin. It will work fine.
Steve
Old 02-07-2021, 08:39 AM
Very interesting, thank you ! I'll try.
Originally Posted by Longez View Post
Luke,
Attachment 8053
Steve
Luke
http://www.rv8.it
CrewRV8 team leader
=VAF= 2021
rongawer rongawer is offline
Default Fly.garmin.com
I have a Garmin Pilot account and after each flight, my flight and engine data automatically syncs to their website that I can view with each log entry. It's a very nice graphical interface and I haven't had to do any export, imports or uploads, so it's easy too.
fly.garmin.com
Ron Gawer
- RV10, N762G, Build in progress.
- Several others that are now just great memories for me.
