FlyFastJP
I'm wanting to swap to an SDS ignition on my RV-4. My plane currently has a 122 tooth ring gear on the flywheel with the matching starter. The SDS flywheel comes with a 149 tooth ring gear. If I bought their flywheel with no ring gear, could I just install a 122 tooth ring gear and everything line up right with my starter?
Yes, I already asked Ross. He's not sure.
