  #11
Old 02-14-2021, 02:17 PM
wilddog wilddog is offline
Originally Posted by rockitdoc View Post
why there is no option for a plain mag and an e-mag.
You can certainly use a plain mag and an e mag but you will have to start on the e mag only and have no option to hand crank if your battery is dead. You have to have an impulse mag to start.
Old 02-14-2021, 02:47 PM
What William says is true. But if you were forced to do that because of a problem with your impulse mag, would you really want to do that? The only way I would consider doing that would be to start the engine so I could taxi the airplane to some maintenance hangar when away from home - and I might not even do it then. What if the problem was with the impulse coupling on the mag? Well documented, hence the ADís on Slick impulse couplings. I wouldnít want to destroy my engine via chewed up metal in my accessory case because of the impulse failure for expediency reasons.
I guess you should ask yourself the question..... what is more reliable, an electronics ignition system, or an impulse-coupled tractor magneto. We know the answer on the tractor mag. We donít have enough experience with most electronic ignition systems on airplane engines to make a valid comparison. We canít really compare automotive ignition systems with their aircraft modified counterparts for the same reason, but usually advancement in these areas can be assumed to a certain degree. Thatís why I have had electronic ignition on all five of the RVís Iíve owned, and two eMags on my last RV8. However - getting rid of that impulse coupling, in my opinion, is a good move in terms of reliability, with no downside.
SH
RV6/2001 built/sold 2005
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019 Flying
Cincinnati, OH/KHAO
JAN2021
Old 02-14-2021, 04:07 PM
BlndRvtr BlndRvtr is offline
Default Starting on an e-mag alone
To those that start only via an electronic mag, is that working well for you? Any conditions where you wish you had a traditional impulse coupling?
George
Old 02-14-2021, 04:31 PM
Carl Froehlich's Avatar
George
The short answer in #!*$ no.
Dual pMags - both on for engine start. Simple, easy, reliable.
Carl
Old 02-14-2021, 05:56 PM
I had one emag on my last RV, on the left and used for engine start. Then I replaced the right mag with a second emag and used both for engine start. Both ways worked very well.
I now have a SureFly on the left, mag right (RV4), and it also starts very well on the SureFly alone.
SH
Cincinnati, OH/KHAO
JAN2021
Old 02-14-2021, 08:10 PM
Ferdara Ferdara is offline
Thatís very interesting I was going to call them on this Monday getting ready to pull the trigger on a RV14A Qbuild, Flying RV9A over 500 hrs with 2 p-mags, Love them! Doing the Thunderbolt was trying to decide on Lycoming E-Mags or what I know and love P-Mags. Mark
Ive decided to go full monty. Ordered engine with one emag and none on other side. I told lycoming the plan is to put on a second emag. Lycoming cant put second emag on at factory cuz of lawyers. So, they will prep engine for second emag. Btw, i emailed both emag and lycoming re this plan and they both got back to me immediately. Impressive.
Ferdara Mark Hubbard
KLFT - Lafayette LA
N596RV - RV9A
#SunShine2020
Old 02-14-2021, 10:12 PM
Funguy's Avatar
Funguy Funguy is offline
Default No issues.
I ran a single PMag for many years and eventually went to dual PMags. I never had an issue starting on a single PMag and now start with both. YMMV.
Cheers, Sean
RV6, Flying C-GOFG
CLA4 - Holland Landing
Toronto ON
Donated to Nov 2021
Old 02-15-2021, 07:28 AM
PhatRV PhatRV is offline
I wonder anyone has used the backup automotive battery to start airplane engine such as the one in the picture below.
RV8 standard build: Empennage 99% completed
Wing -- Closed
Fuselage -- Canopy Done. Fiberglass 80%
Avionics Installation -- 90%
Firewall Forward -- Prep for cowl install
Electrical -- 90%
Donation paid through 2021
Old 02-15-2021, 08:05 AM
olyolson's Avatar
olyolson olyolson is online now
Default Mag
Scott,
I also decided to get rid of the impulse mag after reading a post here on the forum about a freshly rebuilt engine with an impulse mag. The impulse mag failed shortly after he got it back from rebuild and had to take the engine off to fix the issue (see below).
I have an Electroair ignition on one side and will have a non impulse Slick 4130 on the other side, exactly the configuration my buddy has with his RV-10. He starts on the Electroair then brings the non impulse Slick mag on line after engine start.
RV-8, Flying
Previous airplanes: Corby Starlet, Citabria, Cessna 140, Vari-Viggen, RV-3, RV-4
RV grin every flight
"Sure is nice to have smart friends"
2018 dues paid
Old 02-15-2021, 08:59 AM
Desert Rat Desert Rat is online now
Hold up- I believe when the order form says "E-mag" what it means is the P-mag 114 series manufactured By E-Mag Electronic Ignition. NOT the SureFly mag that is starting to show up on the certified engines, which still require a second old school magneto.
That may be a bad assumption on my part? I ordered a Thunderbolt with the 1 e-mag, delete second magneto option, expecting to add a second P-mag 114 when it shows up, but I went back and looked at my thunderbolt order form and it really doesn't specify whether the mag option is surefly or p-mag.
Can somebody verify one way or the other?
Terry Shortt
AGI, CFI, CFII, MEI, A&P, Janitor
RV7 Empennage & Wing done
Fuselage in process
#72651
https://eaabuilderslog.org/?blprojec...t=all&listcat=
