Oil Quick drain.
wildduk
Member
Looking to replace my leaking Curtis quick drain.....thinking the P5000.
The website lists is as stainless and aluminum. Is the threaded section stainless, or is it aluminum.
If I install one, what should I put on the threads to seal it?
I added a SAF-AIR P5000 to mine about 2 months ago. I believe the threads are aluminum, but don't quote me on that. It felt like aluminum while torqueing it, for what it's worth :)
I can say that it appears to be of very high quality. I used Loctite 567 (https://www.amazon.com/Loctite-234451-Sealant-degrees-Temperature/dp/B005P3KAUW) on the threads and safety'd it.
Best,
-AJ
RV-6 N642DP
Best,
-AJ
RV-6 N642DP
This has been on my engine since the beginning...works great! Nearly 900 hours now, no issues.
Saf Air
I will say Saf Air product support is amazing. This thread reminded me of a problem I was having with mine, it stopped staying open. I emailed them explained the problem and told them it is about 3 yrs old. I got an immediate response asking for my address so they could send me a new one at no cost. Great company that stands behind their products.
