Hi Brains Trust,
I am rapidly coming up to Section 28 - Lower Forward Fuselage. OP62 (EXP119 Install) requires a few holes in the side tunnel to lower skin be used for nutplates, instead of rivets (as an example).
I don't know which engine i will be going with at this stage however!
I am thinking maybe EFII meaning it would not be the EXP119, however i could always go with the 4 into 2 exhaust? Too many choices!
Anyway, the question is - do i need to consider the changes for OP62 at this point in Section 28? Or can these be done fairly easily after?
Is there any part of OP62 which would be way harder to do later, which i should consider doing now, despite not knowing what engine i will go with?
Thanks in advance for opinions on how to proceed.
