Motor Mount Pattern Needed
DanH
Legacy Member
Mentor
Need a little help please. Subject is the firewall insulation kits for the 14 and 14A. I have a few beta installations in progress, but only one has a motor mount. Initial fit up says I need to modify the cut patterns to accommodate the bar connecting the lower outer and lower inner mount points. Apparently it fits flush to the firewall.
Anyway, simple request...two actually, 7 and 7A. I need tracings of the lower mount points and connecting bar. Lay the mount on a flat surface, slip a strip of poster board or heavy paper under the lower mount points, and trace around the weldments and connecting bar. See below.
A sketch with good dimensions would probably work too.
PM please. Beer is on me.
