  #11
Old 04-19-2022, 08:37 AM
Tony_T's Avatar
Tony_T Tony_T is offline
Default Hinge smoke
The first picture is typical of hinge smoke after a couple hours of flying with the Sensenich prop and dynamically balanced. The second picture is after many hours of flying with the fixed pitch 3-blade Catto. I have over 30 hours now with the Catto and have yet to see any hinge smoke. The Catto is amazingly smooth running. I know not everyone will want to go out and spend a bunch of money on an expensive prop but vibration kills everything eventually. Could be worth the money in the long run.
ID:	24813  Click image for larger version
Tony
E-LSA RV-12 ULS
Old 04-19-2022, 07:12 PM
funflying funflying is offline
Tony is the Catto prop balanced?
Patrick Claar
Arvada, CO BJC
RV12, #401, Flying 2013, N612PC
RV6, 1996-2010 sold
Old 04-19-2022, 07:57 PM
Tony_T's Avatar
Not dynamically balanced on my airplane, yet. I plan to check that next month at annual time. Will it need any weights? Pretty sure it won't.
Tony
E-LSA RV-12 ULS
Old 04-20-2022, 10:02 AM
RandomSquawk RandomSquawk is offline
Originally Posted by Tony_T View Post
...fixed pitch 3-blade Catto....the Catto is amazingly smooth running.
Tony, do you have a link to that specific product? The Catto web site is not helpful.
Old 04-20-2022, 12:54 PM
Tony_T's Avatar
They do not have the RV12 propeller package currently on their website. I recommend emailing them or call their phone number and talk to Nicole (Catto) Klith. She is director of sales and handles the RV12 propellers. She will know what you are calling about and can answer questions, 209-754-3553 - info@cattoprops.com
Tony
E-LSA RV-12 ULS
Old 04-21-2022, 12:13 AM
KiloFoxtrot's Avatar
KiloFoxtrot KiloFoxtrot is offline
Can anyone show a picture of the broken hinge?
Is it the same hinge eyelets that are wearing and breaking?
Is there a fix during the build which would prevent this?
RV7A tip up
Superior IO-360-M1S Aerosport build school=Excellent. See post: Engine build school pictures IO-360
Tail / Fuse / Wings are complete + painted. I used Sherwin Williams JetGlo solids and AcryGlo metalics.
Leather seats by Flightline Interiors.
Still to do: Firewall forward, cowling fit and paint, G3X avionics.
FLY
Dues Paid
Old 04-21-2022, 12:41 AM
seagull seagull is offline
Typically the co-pilot side is where the most vibration/ wear occurs. See post #3 of this thread for the repair.
There are 2 types of hinge material. One has rolled eyes the other has machined eyes. The machined ones are far superior and can be bought from Spruce. If I was building that is all I would use.
Live as if you were to die tomorrow. Learn as if you were to live forever.
-- Walt --
Old 04-21-2022, 01:34 AM
Piper J3's Avatar
Piper J3 Piper J3 is offline
I wonder why co-pilot side? P-factor from prop? Turbulence from protruding round exhaust stack? Air turbulence around/thru cowl opening for exhaust stack?
Jim Stricker - EAA #499867
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 815
Old 04-21-2022, 04:26 AM
blythet blythet is offline
I think it's because the pilot's side is stiffened by the fiberglass air ducting. No such support on the right side.
Old 04-21-2022, 08:45 AM
it could be the antinode of the vibration occurring at cruise RPM.
-- Walt --
