Another ContourHD Video
Fun video - I really noticed the green grass! Ours tends to be white around now...
What program did you use to edit it?
Video Editor
The Video editor I use is Adobe Premiere Elements. It has a ton of features and makes the editing quite easy.
Mike, what a pleasant surprise to see my old home airport. Kept my champ there from '79 to '83. Am doing phase I on my -4, got 32hrs, 8 more to go; my first x-country will be to Vine Grove to show Randy and Roger over at E-town. Back then we did Rough River nearly every weekend. See you soon.
Jim Woolf
Hickory, Nc
Rv-4 N17JW
Phase I
Now I can show my wife
Hey Mike,
Thanks for the video. I just visited your home port in September. I was on a long cross country from my home in WA and gave several rides out of there. My wife did not get to go and now I can share one of the more interesting airports with her.
I saw your yellow bird tucked away but did not venture close as I was not invited.
Tim
Vine Grove
Jim, I passed along the info to Randy. He is looking forward to your next visit.
Tim, If I had known you were there we could have had a burger. It is a neat country, old fashioned airport as I am sure you saw.
Mike, what is the resolution of your video you posted in March '08?
Any photos of your bracket?
I am in the porcess of evaluating video camera for my RV-6A.
Thanks, Lothar from Colorado
Camera
Lothar,
The camera was the ContourHD by Vholdr. http://www.vholdr.com/
I believe they have three versions a 720, HD and 1020i. Mine is the HD and you can record at 720 also.
I don't have any pictures of the bracket as it is just a 1x3 inch piece, bent in the middle. I drilled a hole in each side, one for the camera and one for the wing tie down bolt hole and used bolts and washers as needed. I was worried at first that it might vibrate loose but it didn't move at all during two 1 hour flights. This camera has a neat feature in that you can rotate the lens to record on it's side which made making a bracket easy and then just turning the lens 90 degrees.
Other camera options
If you are looking to capture more than 1 angle at a time, you may consider our MotoCam Shockbox system that will give you up to 4 angles at the same time and it's all controlled from inside the cockpit:
Let me know if you have any camera or mounting questions.... happy to help.
Tim
http://www.MotoCam360.com
